LOOP PROBLEM!!
1 svar · 186 visningar · startad av znyder
znyderMedlem sedan dec. 2002172 inlägg
http://hashasp.mine.nu/paster/?id=567
Där finner ni mitt problem ;( Snabba svar skulle va jättebussigt ;)
Engine^Medlem sedan dec. 20003 887 inlägg
Felmeddelande?
Prova om detta fungerar... samma kod i stort förutom några uppenbara förändringar :)
Function status(level, nicket)
  level = "" & level
  strSql = "SELECT level_status, next_level FROM person WHERE username = '" & nicket & "'"
  Set RStemp = MinCon.Execute(strSql)
  levels = RStemp("level_status") + level
  If levels => RStemp("next_level") Then
    levels = levels - RStemp("next_level")
    next_level = RStemp("next_level") + 100
    new_levels = RStemp("level") + 1
    strSql = "UPDATE person SET next_level = " & next_level & ", [level] = " & _
              new_levels & " WHERE username = '" & nicket & "'"
    MinCon.Execute strSql, , 128
  RStemp.Close : Set RStemp = Nothing
  strSql = "UPDATE person SET level_status = " & levels & " WHERE username = '" & nicket & "'"
End Function
[b][red]Set rs = Server.CreateObject("ADODB.Recordset")[/red][/b]
Set MinCon = Server.CreateObject("ADODB.Connection")
MinCon.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.Mappath("listmygames.mdb")
strSql = "SELECT username, level_status FROM person WHERE aktiverad = 'ja'"
[b][red]Set rs = MinCon.Execute(strSql)[/red][/b]
Do while NOT [b][red]rs[/red][/b].EOF
  strSql = "SELECT COUNT(*) FROM games WHERE username = ' " & [b][red]rs[/red][/b]("username") & "'"
  Set temp = MinCon.Execute(strSql)
  Response.Write "<B>" & [b][red]rs[/red][/b]("username") & " (" & temp(0) * 15 & ")</B><BR>"
  strSql = "SELECT username FROM games WHERE username = '" & [b][red]rs[/red][/b]("username") & "'"
  Set RStemp2 = MinCon.Execute(strSql)
  Do While Not RStemp2.EOF
    If Not IsNull([b][red]rs[/red][/b]("level_status")) Then
      Call status(15, RStemp2("username"))
    Response.Write RStemp2("title") & " <B>15</B><BR>"
    RStemp2.MoveNext
  Loop
  Response.Write "<P>"
  [b][red]rs[/red][/b].MoveNext
Loop
RStemp2.Close : Set RStemp = Nothing
rs.Close : Set RStemp = Nothing
141 ms totalt · 3 externa anrop · v20260731065814-full.3ab8d573
