Drop&cut
2 svar · 237 visningar · startad av Rod
RodMedlem sedan aug. 200246 inlägg
Jag har kodat ett drop and cut script men jag vill att en html fil uppdateras och listar filnamnen och storleken på filerna i en katalog varje gång jag skickar upp något. Hur kan man lösa det?
Min kod
' Check if user really dropped any files,
' if not, don't perform any tasks
Set objArgs = WScript.Arguments
If objArgs.Count() then
' Get windows directory
  Set objShell = CreateObject("WScript.Shell")
  Set objSysEnv = objShell.Environment("Process")
  strWinDir = objSysEnv("WINDIR") & "\"
  ' Set this to false to disable logging of last file/files sent.
  bolEnableLogging = True
  ' Initiate some variables
  Dim objFS, objFile, objDroppedFiles
  Dim strServer, strFolder, strUser, strPass, strFilePrefix
  strServer = "" ' This is your servername, eg. ftp.mydomain.com
  strFolder = "" ' This is the remote folder you want to put your files in
  strUser = "" ' This is your username
  strPass = "" ' This is password
  strFilePrefix = "" ' This is an arbitrary string.
  ' Create an extra string to enable logging.
  If bolEnableLogging Then strLogText = " > " & strWinDir & strFilePrefix & "_log.txt"
  ' Open an empty file for ftp commands
  Set objFS = CreateObject("Scripting.FileSystemObject")
  Set objFile = objFS.OpenTextFile(strWinDir & strFilePrefix & "_send.txt", 2, True)
  ' Write FTP commands to the file
  objFile.WriteLine "open " & strServer
  objFile.WriteLine strUser
  objFile.WriteLine strPass
  objFile.WriteLine "cd " & strFolder
  objFile.WriteLine "binary"
  For Each objDroppedFiles in objArgs
    objFile.WriteLine "put """ & objDroppedFiles & """"
  Next
  objFile.Write "quit"
  objFile.Close
  Set objFile = Nothing
  ' Run ftp.exe
  objShell.Run "%comspec% /c ftp.exe -i -s:" & strWinDir & strFilePrefix & "_send.txt" & strLogText, 0, True
  Set objShell = nothing
  ' Give a little feedback to the user
  WScript.Echo("Uploaded " & objArgs.Count() & " files.")
  ' Delete the temporary ftp command file.
  If objFS.FileExists(strWinDir & strFilePrefix & "_send.txt") = True Then
    objFS.DeleteFile strWinDir & strFilePrefix & "_send.txt", True
  End if
  Set objFS = Nothing
  Set objArgs = Nothing
1. Känns som en ASP-fråga. Jag har meddelat moderator för flytt.
2. V.v. använd [kod]-taggar.
Flyttad från HTML, XHTML & CSS.
mvh Palle
Moderator webForum
272 ms totalt · 3 externa anrop · v20260731065814-full.beb2e261
131 ms — hämta forumlista (db)
127 ms — hämta statistik (db)
