Få fram antal inlägg mm i nyhetsscript?
23 svar · 274 visningar · startad av Korak
Medlem sedan maj 2001133 inlägg
Skulle någon kunna hjälpa mig med hur jag ska göra för att få fram "Du är på sid X av X det finns totalt X nyheter inlagda." i detta script:
<!-- #include file="data.asp" -->
dim data, strDB, page, display, include_page, num_items, multi, intCount, show_email, linked_page
if request.querystring("page") = "" then
page = 1
page = request.querystring("page")
set data = server.createobject("ADODB.Recordset")
data.activeconnection = strDB
data.source = "SELECT * FROM admin WHERE id = 1"
data.open
num_items = data("items_per")
display = data("display")
include_page = data("included_page")
multi = data("multi")
show_email = data("show_email")
if data("linked_page") = "none" then
linked_page = include_page
linked_page = data("linked_page")
data.close
if request.querystring("id") <> "" then
data.source = "SELECT * FROM news WHERE id = " & request.querystring("id")
data.cursortype = 2
data.cursorlocation = 3
data.locktype = 3
data.open
if show_email = "yes" then
show_email = "</b> <a href=""mailto:" & data("author_email") &""">" & data("author_email") & "</a></p>"
show_email = ""
response.write data("news_date") & "<br>"
response.write "<b>" & data("news_title") & "</b><p>"
response.write data("news_text") & "</p><p>"
response.write "<b>" & data("news_author") & "</b><br>"
response.write show_email
response.write "<a href=""javascript:history.back()""><< Tillbaka </a>| "
response.write "<a href=""" & include_page & """>Nyheter</a>"
SQL = "SELECT COUNT (id) AS antalPoster FROM news"
data.open SQL
posts = data("antalPoster")
itemNumber = (page-1)*data.pagesize + intCount
response.write " Detta är Nyhet <b>" & itemNumber & "</b> av totalt <b>" & posts &"</b>"
show = "no"
if show = "" then
set data = server.createobject("ADODB.RecordSet")
data.source = "SELECT * FROM news ORDER BY id DESC"
data.cursortype = 3
data.locktype = 3
data.pagesize = num_items
data.open
data.absolutepage = page
intCount = 0
while not data.eof and intCount < data.pagesize
intCount = intCount + 1
if display = "A" then
show_email = ""
response.write "<font size=""4""><b>" & data("news_title") & "</font></b> " & data("news_date") & "<br>"
response.write "<font size=""2"">" & data("news_text") & "</font><br><br>"
response.write "Skrivet av: <b>" & data("news_author") & show_email
response.write "<hr>"
if display = "B" then
response.write "<a href=""" & linked_page & "?id=" & data("id") & """>" & data("news_title") & "</a><br><br>"
if display = "C" then
response.write "<br><a href=""" & linked_page & "?id=" & data("id") & """>" & data("news_title") & "</a><br>"
response.write "<font size=""2"">" & left(data("news_text"), 40) & "...</font><br>"
data.movenext
wend
response.write "<br><br>"
if multi = "yes" then
if page > 1 then
response.write " <a href=""" & include_page & "?page="& page - 1 & """><< Tillbaka </a>| "
data.open SQL
totalPages = int((posts-1)/num_items + 1)
response.write "Sid <b>"& page &"</b> av <b>"& totalPages &"</b> | "
if not data.eof then
response.write "<a href=""" & include_page & "?page="& page + 1 & """>Nästa >></a>" & "   Det finns <b>" & posts & "</b>" & " Nyheter totalt."
data.close
Tack på förhand!
//Korak
[Redigerat av Korak den 04 jul 2001]
'## COUNT ALL POSTS
SQL = "SELECT COUNT(*) AS cnt FROM [news]"
set mySQL = Conn.Execute(SQL)
antal = mySQL("cnt")
' ## PRINT
response.write "Det finns " & antal & " nyheter."
I sometimes wish I was famous.
Hmmm...funkade inte.
Jag har försökt som en galning, känns som jag prövat allt.
Min senaste variant som självklart inte funkade:
'## COUNT ALL POSTS
data.open
' ## PRINT
Response.Write "Antal nyheter: <b>" & data("antalPoster") & "</b>"
data.close
Får detta felmeddelande:
Microsoft JET Database Engine error '80040e0c'
Command text was not set for the command object.
/nyheter/show_news.asp, line 107
//Korak
data.open [b] SQL [/b]
' ## PRINT
data.close
Äntligen :)
Glädje.
Tack så mycket för hjälpen LarsG!
//Korak
En sista fråga i ämnet.
Jag har lyckats få fram vilken sidan besökaren är på med denna kod:
response.write "Sid <b>"& page &"</b> av <b>"& count &"</b>
Det som jag inte får till är det totala antalet sidor (där det nu står count).
Någon som skulle kunna vara vänlig att hjälpa mig med detta?
Tack på förhand!
//Korak
Om antalet psoter per sida är pageSize så kan du räkna ut antalet sidor så här
items = data("antalPoster")
totalPages = (items-1)/pageSize + 1
Känns nästan lite pinsamt att fråga igen men det känns som jag verkligen försökt allt. Jag har fått till allt som jag vill ha det nu utom grejen att visa hur många sidor det finns totalt.
Såhär ser nu slutet av koden jag postade tidigare ut:
if page > 1 then
    response.write "Sid \<b\>"& page &"\</b\> av \<b\>"& HÄR\_ÄR_DET_KÖRT &"\</b\>&nbsp;&#0124;&nbsp;"
data.close
data.open SQL
' ## PRINT
Response.Write "  Antal nyheter: <b>" & data("antalPoster") & "</b><br>"
data.close
Vore jätteglad om någon skulle kunna tipsa mig om hur jag ska göra.
Och ja, jag lovar, jag ska köpa "Asp for dummies", "Lär dig asp på 3 veckor" mm :)
//Korak
Jag flyttade om lite kod. Sen så förutsätter jag att du har en variabel som heter num_items som anger hur många poster du visar per sida
if page > 1 then
response.write " <a href=""" & include_page & "?page="& page - 1 & """><< Tillbaka </a>&#0124; "
data.open SQL
data.close
'# num_items är antal poster som visas per sida
totalPages = (posts-1)/num_items + 1
response.write "Sid <b>"& page &"</b> av <b>"& totalPages &"</b> &#0124; "
data.close
' ## PRINT
Response.Write "  Antal nyheter: <b>" & posts & "</b><br>"
Jag har för mig att jag testade något liknande. Jag får fram detta felmeddelande:
Sid 1 av 3.16666666666667 |
ADODB.Recordset error '800a0e78'
Operation is not allowed when the object is closed.
/nyheter/show_news.asp, line 104
Detta är rad 104:
Det känns ju som det är så nära att funka...jag fattar inte.
//Korak
och om du tar bort raden data.close?
can i borrow your goat?
</A>
Nu är det mycket, mycket nära :)
Jag tog bort data close i raden som låg över denna:
Nu funkar allt förrutom att det istället för att stå "Sid 1 av 3" står "Sid 1 av 3.16666666666667"
Förslag?
//Korak
det borde väl vara sidan 1/4???
prova att slänga int() runt totala antalet sidor.
</A>
Nej det är Sid 1 av 3 som det ska vara. Jag har sex inlägg på varje sida. Jag prövade att skriva in 2 nya inlägg. Då ändrades det till Sid 1 av 3,5
Nu är det totalt 16 inlägg.
Vet inte om jag förstod vad du menade riktigt @nders. Jag prövade att ta bort alla int i koden...ingen skillnad. Sedan prövade jag att ta bort parantesen runt (posts-1)...ingen skillnad. Var det något av de alternativen du menade?
//Korak
åh jäklarns vilken missufattning!
förlåt mig, korak, jag skulle givetvis gett kodexempel såsom LarsG gjorde.
sorry! :)
</A>
Jiipppiiiieeeeee!!! :e
Äntligen...glädje.
Tack så hemskt mycket för hjälpen!
//Korak
Du behöver verkligen inte be om ursäkt @nders :)
Jag blir så otroligt glad över att det finns så många underbara människor som vill hjälpa till.
//Korak
En sista gång jag lovar :)
Försöker få fram vilket nummer i ordningen varje inlägg har. Har klurat fram och tillbaka men som vanligt inte lyckats. Nu ser det ut såhär:
data.open SQL
response.write " Detta är Nyhet \<b\>" & id & "\</b\> av totalt \<b\>" & posts &"\</b\>"
show = "no"
Nu syns det ingenting där "id" står.
Nån känner sig sugen att komma med ett tips?
//Korak
122 ms — deklarationer (db)
143 ms — hämta tråd, inlägg och bilagor (db)
121 ms — ändringar (db)
