Mapp problem
10 svar · 417 visningar · startad av jlee
jleeMedlem sedan dec. 2002378 inlägg
Detta script gör thumbnails av stora bilder. Man ska kunna välja vecka i en scroll list. Problemet är att mappen som man väljer inte hittar bilderna i den utan det blir ett kryss istället för bild.
jag hamnar allstå utanför mappen jag vill till??
If Request.QueryString("do") = "" Then
  Dim FSO
  Dim Files
  Dim File
  Dim Count
  Dim vFolder ' skapa variabel
  vFolder = Request("folder") ' hämta mappnamnet
  Const Columns = 2
  Const ImageWidth = 100
  Set FSO = Server.CreateObject("Scripting.FileSystemObject")
  Set Files = FSO.GetFolder(Server.MapPath("./" & vFolder)).Files ' lägg in variabel
  Set FSO = Nothing
  Response.Write "<TABLE width=""200px"" border=""0"" cellspacing=""0"">"
  Response.Write "<TR>"
  Count = 0
  For Each File In Files
  Select Case LCase(Right(File.Name, 3))
  Case "jpg", "gif", "bmp", "png"
  Count = Count + 1
  if Count Mod Columns = 1 Then Response.Write "</TR><TR>"
  Response.Write "<TD  align=""center"" valign=""top"">"
Response.Write "<A href=""vanster.asp?image=" & File.Name & """ target=""vanster"" >"
  Response.Write File.Name
  Response.Write "<BR><IMG src=""" & File.Name & """ border=""2"" width=""" & ImageWidth & """></a><BR>"
  Response.Write "</TD>"
  End Select
  Next
  Response.Write "</TR>"
  Response.Write "</TABLE>"
  Set File = Nothing
  Set Files = Nothing
ElseIf Request.QueryString("do") = "delete" Then
  Set objFSO = Server.CreateObject("Scripting.FileSystemObject")
  If objFSO.FileExists(Server.MapPath(Request.QueryString("bild"))) Then
  objFSO.DeleteFile(Server.MapPath(Request.QueryString("bild")))
  Set objFSO = Nothing
  Response.Redirect("?do=")
%></p><div align="center">
<form name="form1" method="post" action="hoger.asp">
  <select name="folder" onChange="document.form1.submit();">
  <option selected>Välj vecka</option>
  <option value="20">Vecka 20</option>
  <option value="21">Vecka 21</option>
  <option value="22">Vecka 22</option>
  <option value="23">Vecka 23</option>
  </select>
</form></div>
henkzMedlem sedan apr. 2002183 inlägg
byt ut:
mot:
Response.Write "<BR><IMG src=""" &vFolder&"/"& File.Name & """ border=""2"" width=""" & ImageWidth & """></a><BR>"
... och vänligen använd [kod]-taggar.
mvh
Verkar inte funka..ska det kanske vara en ändring i länken också?
Antagligen samma ändring isåfall:
Response.Write("<a href=""vanster.asp?image=" & vFolder & "/" & File.Name & """ target=""vanster"">")
Det var inte det som var problemet....funkar fortf inte
vecko mappen öppnas inte konstigt nog..
Kan någon hitta felet som gör att scriptet inte funkar?
Det är ju inget scriptfel, det är bara att mappstrukturen inte ser ut som scriptet är kodat till. Det är ju bara att du ser över sökvägarna så löser det sig.
Kan dessvärre inte förstå hur jag ska ändra för att lösa problemet?
130 ms totalt · 3 externa anrop · v20260731065814-full.3ab8d573
