Pure ASpUpload
0 svar · 158 visningar · startad av pellsäter
pellsäterMedlem sedan aug. 2000526 inlägg
Hej använder mig av PureAspUpload!
KÄnner någon till den koden!! Jag skulle vilja lägga till så att det skapas ett filnamn i en databas för varje bild som läggs in!
<%@LANGUAGE="VBSCRIPT"%> <%
'*** File Upload to: image_egnabilder, Extensions: "GIF,JPG,JPEG,BMP,PNG", Form: bild, Redirect: "laggtillbild2.asp"
'*** Pure ASP File Upload -----------------------------------------------------
' Copyright 2000 (c) George Petrov
' Script partially based on code from Philippe Collignon
' (http://www.asptoday.com/articles/20000316.htm)
' New features from GP:
' * Fast file save with ADO 2.5 stream object
' * new wrapper functions, extra error checking
' * UltraDev Server Behavior extension
' Version: 1.5.0
Sub BuildUploadRequest(RequestBin)
'Get the boundary
PosBeg = 1
PosEnd = InstrB(PosBeg,RequestBin,getByteString(chr(13)))
if PosEnd = 0 then
Response.Write "<b>Formuläret är inte ett s.k. ENCTYPE=""multipart/form-data""</b><br>"
Response.Write "Rätta och försök igen"
Response.End
boundary = MidB(RequestBin,PosBeg,PosEnd-PosBeg)
boundaryPos = InstrB(1,RequestBin,boundary)
'Get all data inside the boundaries
Do until (boundaryPos=InstrB(RequestBin,boundary & getByteString("--")))
'Members variable of objects are put in a dictionary object
Dim UploadControl
Set UploadControl = CreateObject("Scripting.Dictionary")
'Get an object name
Pos = InstrB(BoundaryPos,RequestBin,getByteString("Content-Disposition"))
Pos = InstrB(Pos,RequestBin,getByteString("name="))
PosBeg = Pos+6
PosEnd = InstrB(PosBeg,RequestBin,getByteString(chr(34)))
Name = getString(MidB(RequestBin,PosBeg,PosEnd-PosBeg))
PosFile = InstrB(BoundaryPos,RequestBin,getByteString("filename="))
PosBound = InstrB(PosEnd,RequestBin,boundary)
'Test if object is of file type
If PosFile<>0 AND (PosFile<PosBound) Then
'Get Filename, content-type and content of file
PosBeg = PosFile + 10
FileName = getString(MidB(RequestBin,PosBeg,PosEnd-PosBeg))
FileName = Mid(FileName,InStrRev(FileName,"\")+1)
'Add filename to dictionary object
UploadControl.Add "FileName", FileName
Pos = InstrB(PosEnd,RequestBin,getByteString("Content-Type:"))
PosBeg = Pos+14
'Add content-type to dictionary object
ContentType = getString(MidB(RequestBin,PosBeg,PosEnd-PosBeg))
UploadControl.Add "ContentType",ContentType
'Get content of object
PosBeg = PosEnd+4
PosEnd = InstrB(PosBeg,RequestBin,boundary)-2
Value = FileName
ValueBeg = PosBeg-1
ValueLen = PosEnd-Posbeg
Else
Pos = InstrB(Pos,RequestBin,getByteString(chr(13)))
PosBeg = Pos+4
Value = getString(MidB(RequestBin,PosBeg,PosEnd-PosBeg))
ValueBeg = 0
ValueEnd = 0
'Add content to dictionary object
UploadControl.Add "Value" , Value
UploadControl.Add "ValueBeg" , ValueBeg
UploadControl.Add "ValueLen" , ValueLen
'Add dictionary object to main dictionary
UploadRequest.Add name, UploadControl
'Loop to next object
BoundaryPos=InstrB(BoundaryPos+LenB(boundary),RequestBin,boundary)
Loop
End Sub
'String to byte string conversion
Function getByteString(StringStr)
For i = 1 to Len(StringStr)
char = Mid(StringStr,i,1)
getByteString = getByteString & chrB(AscB(char))
Next
End Function
'Byte string to string conversion
Function getString(StringBin)
getString =""
For intCount = 1 to LenB(StringBin)
getString = getString & chr(AscB(MidB(StringBin,intCount,1)))
Next
End Function
Function UploadFormRequest(name)
on error resume next
if UploadRequest.Item(name) then
UploadFormRequest = UploadRequest.Item(name).Item("Value")
End Function
'Process the upload
UploadQueryString = Replace(Request.QueryString,"GP_upload=true","")
if mid(UploadQueryString,1,1) = "&" then
UploadQueryString = Mid(UploadQueryString,2)
GP_uploadAction = CStr(Request.ServerVariables("URL")) & "?GP_upload=true"
If (Request.QueryString <> "") Then
if UploadQueryString <> "" then
GP_uploadAction = GP_uploadAction & "&" & UploadQueryString
If (CStr(Request.QueryString("GP_upload")) <> "") Then
GP_redirectPage = "laggtillbild.asp"
If (GP_redirectPage = "") Then
GP_redirectPage = CStr(Request.ServerVariables("URL"))
RequestBin = Request.BinaryRead(Request.TotalBytes)
Dim UploadRequest
Set UploadRequest = CreateObject("Scripting.Dictionary")
BuildUploadRequest RequestBin
GP_keys = UploadRequest.Keys
for GP_i = 0 to UploadRequest.Count - 1
GP_curKey = GP_keys(GP_i)
'Save all uploaded files
if UploadRequest.Item(GP_curKey).Item("FileName") <> "" then
GP_value = UploadRequest.Item(GP_curKey).Item("Value")
GP_valueBeg = UploadRequest.Item(GP_curKey).Item("ValueBeg")
GP_valueLen = UploadRequest.Item(GP_curKey).Item("ValueLen")
  if GP_valueLen = 0 then
    Response.Write "\<B\>An error has occured saving uploaded file!\</B\>\<br\>\<br\>"
    Response.Write "Filename: " & Trim(GP_curPath) & UploadRequest.Item(GP_curKey).Item("FileName") & "\<br\>"
    Response.Write "File does not exists or is empty.\<br\>"
    Response.Write "Please correct and \<A HREF=""javascript:history.back(1)""\>try again\</a\>"
  	  response.End
  'Create a Stream instance
  Dim GP_strm1, GP_strm2
  Set GP_strm1 = Server.CreateObject("ADODB.Stream")
  Set GP_strm2 = Server.CreateObject("ADODB.Stream")
  'Open the stream
  GP_strm1.Open
  GP_strm1.Type = 1 'Binary
  GP_strm2.Open
  GP_strm2.Type = 1 'Binary
  GP_strm1.Write RequestBin
  GP_strm1.Position = GP_ValueBeg
  GP_strm1.CopyTo GP_strm2,GP_ValueLen
  'Create and Write to a File
  GP_curPath = Request.ServerVariables("PATH_INFO")
  GP_curPath = Trim(Mid(GP_curPath,1,InStrRev(GP_curPath,"/")) & "image_egnabilder")
  if Mid(GP_curPath,Len(GP_curPath),1) \<\> "/" then
    GP_curPath = GP_curPath & "/"
  GP_strm2.SaveToFile Trim(Server.mappath(GP_curPath))& "\\" & UploadRequest.Item(GP_curKey).Item("FileName"),2
  if err then
    Response.Write "\<B\>Bågot har gått fel vid själva processandet\</B\>\<br\>\<br\>"
    Response.Write "Kanske finns inte mappen du vill skriva till eller så har du inte skrivrättigheter\<br\>"
    Response.Write "Rätta och \<A HREF=""javascript:history.back(1)""\>försök igen\</a\>"
	  err.clear
  	  response.End
next
'***GP BEGIN REDIRECT: with URL parameters (only if no Insert/Update)
If (GP_redirectPage <> "") Then
If (InStr(1, GP_redirectPage, "?", vbTextCompare) = 0 And UploadQueryString <> "") Then
GP_redirectPage = GP_redirectPage & "?" & UploadQueryString
Call Response.Redirect(GP_redirectPage)
'***GP END REDIRECT
UploadQueryString = UploadQueryString & "&GP_upload=true"
UploadQueryString = "GP_upload=true"
133 ms totalt · 3 externa anrop · v20260731065814-full.beb2e261
