redigerare
ASPur ASP
4 svar · 314 visningar · startad av jonfor
jonforMedlem sedan mars 200170 inlägg
när jag försöker använda den här koden får jag bara felmedelandet:
Ny ledig tjänst Serverobjekt fel 'ASP 0177 : 800a004c' Server.CreateObject misslyckades /chick/admin.asp, rad 187 00000000
<html>
<title>Admin</title>
<body>
'Kod skapad av Jens Nilsson Sweden 2000
Response.Write "<b>Välkommen till Jens fenomenala adminsystem för HTML dokument</b><br><br>"
Dim dokVar, rubVar, textVar, actionVar, folder, Rubrik, Text
dokVar = Request("dokument")
rubVar = Request("rubrik")
textVar = Request("text")
actionVar = Request("action")
'Get path to folder wich contains the files
folder = Server.MapPath("notes/")
Rubrik = ""
Text = ""
'Choose wich action you want to do
Select Case actionVar
'For Saving document
Case "Spara"
Dim Create, Write, savePath, file, count
Set Create = Server.CreateObject("Scripting.FileSystemObject")
'Replace all the vbcrlf with html breaks
textVar = Replace(textVar, vbcrlf, "<br>")
'Check if the document's first letters is "dok"
If Left(dokVar, 3) = "dok" Then
savePath = Create.BuildPath(folder, dokVar)
Set Write = Create.OpenTextFile(savePath, 2)
Write.WriteLine "<!--" & rubVar & "-->"
Write.WriteLine "<html>" & vbcrlf & "<head>" & vbcrlf & "<title>Atomatiskt dokument</title>" & vbcrlf & "</head>" & vbcrlf & "<body>" & vbcrlf & "<br>"
Write.WriteLine "<p><b><i>" & vbcrlf & rubVar & vbcrlf & "</i></b></p>" & vbcrlf
Write.WriteLine "<p>" & vbcrlf & textVar & vbcrlf & "</p>" & vbcrlf
Write.WriteLine "</body>" & vbcrlf & "</html>"
Write.Close
Response.Write "Filen har sparats som " & dokVar & "<br>" & vbcrlf
Else
count = 1
file = "dok0" & count & ".asp"
savePath = Create.BuildPath(folder, file)
Do Until Create.FileExists(savePath) = False
count = count + 1
Loop
If Create.FileExists(savePath) = False Then
Set Write = Create.CreateTextFile(savePath, 2)
Write.WriteLine "<html>" & vbcrlf & "<head>" & vbcrlf & "<title>Automatiskt dokument</title>" & vbcrlf & "</head>" & vbcrlf & "<body>" & vbcrlf & "<br>"
Write.Close
Response.Write "Filen har skapats och sparats som dok0" & count & ".asp<br>" & vbcrlf
Else
Response.Write "Filen skapades inte<br>" & vbcrlf
'For removing documents
Case "Ta bort"
If dokVar = "0" Then
Response.Write "Felaktig fil!<br>Du måste välja vilken fil du vill ta bort först<br>" & vbcrlf
Else
Dim Delete, deletePath
Set Delete = Server.CreateObject("Scripting.FileSystemObject")
deletePath = Delete.BuildPath(folder, dokVar)
Delete.DeleteFile deletePath
Response.Write "Filen " & dokVar & " har tagits bort<br>" & vbcrlf
'For editing documents
Case "Editera"
Response.Write "<tr><td>Du måste vaälja vilken fil du vill editera först</td></tr>" & vbcrlf
Else
Dim Edit, editPath, Open, Parse
Set Edit = Server.CreateObject("Scripting.FileSystemObject")
editPath = Edit.BuildPath(folder, dokVar)
Set Open = Edit.OpenTextFile(editPath)
'Skips lines until it reaches line 9
Do Until Open.Line = 9
Open.SkipLine
Loop
'Opens line 9 which contains the headline
Rubrik = Open.ReadLine
'Skips lines until it reaches line 13
Do Until Open.Line = 13
Open.SkipLine
Loop
'Opens line 13 which contains the textcontent
Text = Open.ReadLine
Open.Close
Text = Replace(Text, "<br>", vbcrlf)
Response.Write "Editera<br>" & vbcrlf
'For aborting an action
Case "Avbryt"
Response.Write "Avbruten<br>" & vbcrlf
'Deafault upon loading for the first time
Case Default
If Not request.querystring("content")="reloaded" then
Response.Write "Vänta till sidan laddats om.<br>" & vbcrlf
Response.Write "<meta http-equiv=""Refresh"" content=""0;URL=admin.asp?content=reloaded"">" & vbcrlf
Response.Write "Klar<br>" & vbcrlf
End Select
'Admin dokument buildup
Response.Write "<tr><td colspan=2><form name=dokument action=""admin.asp"" method=""post"">" & vbcrlf
Response.Write "Behandla<br>" & vbcrlf & "<select name=""dokument"" size=1>" & vbcrlf
Response.Write "<option value=""0"" selected>Ny ledig tjänst" & vbcrlf
If actionVar = "Editera" AND Not dokVar = "0" Then
Response.Write "<option value=""" & dokVar & """ selected>" & dokVar & vbcrlf
Else
ScanDir
Response.Write "</select><br><br></td></tr>"
Response.Write "<tr><td>Rubrik<br><input type=""text"" name=""rubrik"" size=""41"" value=""" & Rubrik & """><br><br>"
Response.Write "Innehåll<br><textarea cols=40 rows=15 name=""text"">" & Text & "</textarea><br><br>"
Response.Write "<input type=submit name=""action"" value=""Spara""> <input type=""submit"" name=""action"" value=""Editera""> <input type=""Reset"" value=""Töm""> <input type=submit name=""action"" value=""Ta bort""> <input type=submit name=""action"" value=""Avbryt"">"
Response.Write "</form></td></tr>"
'Function for scanning the directory for automatic dokuments
Function ScanDir
'Declare our variables
Dim objFSO, readFSO, objFolder, fileObject, T, Output
Set objFSO = Server.CreateObject("Scripting.FileSystemObject")
Set readFSO = Server.CreateObject("Scripting.FileSystemObject")
'set our folder object to the web root folder
Set objFolder = objFSO.GetFolder(folder)
For Each fileObject in objFolder.Files
If readFSO.FileExists(fileObject) = True Then
Set T = readFSO.OpenTextFile(fileObject)
Do Until T.Line = 9
T.SkipLine
Loop
'Opens line 9 which contains the textcontent
Output = T.ReadLine
Response.Write "<option value=" & fileObject.Name & ">" & Output & vbcrlf
T.Close
Next
End Function
jag är inte bäst, jag är inte sämst men jag är vettigast. mohahaha
Fluffys
En liten sökning på MSDN gav detta: http://support.microsoft.com/support/kb/articles/Q197/9/64.ASP?LN=EN-US&SD=gn&FR=0&qry=ASP 0177 %3A 800a004c&rnk=1&src=DHCS_MSPSS_gn_SRCH&SPR=ASP
Vide rox = new Vide();
rox.learn("C#");
webeye.nu
jag får den inte att fungera hur jag än ändrar i sökvägen till mappen. Hjälp!
Fluffys
Nu har jag fått sökvägen att fungera men nu kommer det upp några rader ur något html dokument i den mappen. fattar inte hur man ska göra?
Fluffys
Jo, det är ju lite svårt för oss att svara när du inte anger vad scriptet skall göra, och skickar med ett så stort masstodont kodblock.
Berätta vad du vill att scriptet skall göra.
Berätta vad som är fel.
Berätta hur du vill ha det.
Vi är inge tankeläsare... ;)
rox.learn("C#");
webeye.nu
134 ms totalt · 3 externa anrop · v20260731065814-full.29ac60f6
