Svaren ska in i databas??
1 svar · 474 visningar · startad av Falle
Medlem sedan juni 200112 inlägg
Har problem med att få in svaren i en databas??
' Takes a integer parameter and converts it to the appropriate letter
Function GetLetterFromAnswerNumber(iInput)
Dim strTemp
Select Case iInput
Case 0
strTemp = "A"
Case 1
strTemp = "B"
Case 2
strTemp = "C"
Case 3
strTemp = "D"
Case 4
strTemp = "E"
Case 5
strTemp = "F"
End Select
GetLetterFromAnswerNumber = strTemp
End Function
' To simplify and streamline the code I split this line into many parts,
' wrapped it into a function and commented it so you'd have a better
' chance of figuring out what I'm doing since I usually can't!
Function GetAnswerFromAnswerString(iQuestionNumber, strAnswers)
Dim strTemp
Dim iOffset
' I use InStrRev since I want to retrieve the last entered value
' in case they went back and changed their mind.
' Find the location of the question number we want to use
iOffset = InStrRev(strAnswers, "&#0124;" & iQuestionNumber & "&#0124;", -1, 1)
' Get our answer by using the offset we just found and then moving
' right the length of the question indicator to arrive at the
' appropriate letter
strTemp = Mid(strAnswers, iOffset + Len("&#0124;" & iQuestionNumber & "&#0124;"), 1)
' There's no way it should be anything else, but to be sure we
' convert it to a string and make sure it's uppercase
GetAnswerFromAnswerString = UCase(CStr(strTemp))
End Function
' If this is the first call to the quiz then init everything
' o/w retrieve values we need. We check by looking for the
' Question ID from the querystring.
If Request.QueryString("qid") = "" Then
' Retrieve and Set the Quiz Info
If USE_DB_FOR_INFO Then
' Code to use DB!
' Create DB connection and connect to the DB
Set cnnQuiz = Server.CreateObject("ADODB.Connection")
cnnQuiz.Open DB_CONN_STRING
	' Create RS and query DB for quiz info
	Set rsQuiz = Server.CreateObject("ADODB.Recordset")
	rsQuiz.Open "SELECT \* FROM quizzes WHERE quiz_id=" & QUIZ_ID & ";", cnnQuiz
	' Set our session vars
	Session("QuizName") = CStr(rsQuiz.Fields("quiz_name").Value)
	Session("NumberOfQuestions") = CInt(rsQuiz.Fields("number_of_questions").Value)
Else
	' If we're not going to the DB, hard code in values here!
	' BEGIN HARD CODE
	Session("QuizName") = "Fotbolls Quiz"
	Session("NumberOfQuestions") = 10
	'Session("PercentageToPass") = 70
	' END HARD CODE
' Set our question indicator to 1 and init our answer string
iQuestionNumber = 1
Session("AnswerString") = "&#0124;"
Else
'Check to be sure we've still got a session!
If Session("AnswerString") = "" Then
Response.Write "I'm sorry, but you've taken too long. You can start over by "
Response.Write "clicking <A HREF=""" & Request.ServerVariables("URL") & """>here</A>."
' I'd normally just do a response.end, but I can't because I'm inside of our
' site template. I need the script to complete so I've declared and set a Flag
'Response.End
bAbort = True
' Get the number of the question we're processing
iQuestionNumber = CInt(Request.QueryString("qid"))
' Log selected answer to last question
Session("AnswerString") = Session("AnswerString") & iQuestionNumber & "&#0124;" & \_
	GetLetterFromAnswerNumber(CInt(Request.QueryString("sa"))) & "&#0124;"
' Increment question identifier
iQuestionNumber = iQuestionNumber + 1
' If session has expired then skip all the code.
' Equivalently, only run all the code if it hasn't!
If Not bAbort Then
' Set this to a local variable to avoid accessing the collection each time
' This isn't required, but makes it easier for me to access and
' supposedly speeds it up... I'm not sure how much, but it can't hurt!
iNumberOfQuestions = Session("NumberOfQuestions")
' Check to see it the quiz is over.  If so then show results, o/w
' ask the next question
If iQuestionNumber \> iNumberOfQuestions Then
	' Process results and show end quiz status report
	' Done for the same reason as for iNumberOfQuestions a few lines above
	strAnswers = Session("AnswerString")
	' Useful for debugging
	'Response.Write strAnswers & "\<BR\>" & vbCrLf & "\<BR\>" & vbCrLf
	' Bug hunting once again... I didn't even come across any real bugs on this trip!
	' Could you imagine the ammo I'd take if it was real hunting I was doing!
	'For I = 1 to iNumberOfQuestions
	'	Response.Write GetAnswerFromAnswerString(I, strAnswers) & "\<BR\>" & vbCrLf
	'Next 'I
	' Retrieve Correct Answers and compare to the entered ones
		' Code to use DB!
		' Specify 3, 1 (Static, Read Only)
		rsQuiz.Open "SELECT \* FROM questions WHERE quiz_id=" & QUIZ_ID & \_
			" ORDER BY question_number;", cnnQuiz, 3, 1
		iScore = 0
		I = 1
		Do While Not rsQuiz.EOF
			If UCase(CStr(rsQuiz.Fields("correct_answer").Value)) = \_
				GetAnswerFromAnswerString(I, strAnswers) Then
				iScore = iScore + 1
				' This and the Else could be used to output a
				' correctness status for each question
				' Also useful for bug hunting!
				'Response.Write "Right" & "\<BR\>" & vbCrLf
			Else
				'Response.Write "Wrong" & "\<BR\>" & vbCrLf
				strResults = strResults & I & ", "
			I = I + 1
			rsQuiz.MoveNext
		Loop
		' Close and dispose of our DB objects
		rsQuiz.Close
		Set rsQuiz = Nothing
		cnnQuiz.Close
		Set cnnQuiz = Nothing
	Else
		' If we're not going to the DB, hard code in answer values here!
		' BEGIN HARD CODE
		aAnswers = Array("B", "A", "A", "E", "D", "A", "E", "E", "A", "A")
		' END HARD CODE
		iScore = 0
			If UCase(CStr(aAnswers(I - 1))) = \_
				iScore = iScore + 1
			Else
		Next 'I
	' Convert score to a percentage rounded to the whole number
	iScore = Round((iScore / iNumberOfQuestions) \* 100)
    \<BR\>
    \<input type="submit" name="Submit" value="Submit"\>
	If iScore \>= Session("PercentageToPass") Then
		Response.Write "Tack för din medverkan"
		'Response.Write iScore & "%.\<BR\>" & vbCrLf
	Else
		Response.Write "Sorry!  You needed to achieve a score of "
		Response.Write Session("PercentageToPass") & "% or higher to pass.  "
		Response.Write "Unfortunately, your score was only " & iScore & "%.  "
		Response.Write "You can take the test again by clicking \<A HREF="""
		Response.Write Request.ServerVariables("URL") & """\>here\</A\>.\<BR\>" & vbCrLf
	Response.Write "\<BR\>" & vbCrLf
	If Len(strResults) \<\> 0 Then
		'Response.Write "You missed the following questions: " & Left(strResults, Len(strResults) - 2)
		'Response.Write "\<BR\>" & vbCrLf
	'Response.Write iScore & "%"
	' This is also where you could log the results if you wanted to.
	' In it's simplest form, you would simply log strAnswers to a file,
	' but you could format little "report cards" or log the result to a
	' separate data source.
Else
	' Retrieve and Set the Question Info
		' Code to use DB!
		rsQuiz.Open "SELECT \* FROM questions WHERE quiz_id=" \_
			& QUIZ_ID & " AND question_number=" & iQuestionNumber & ";", cnnQuiz
		' Set our question info
		strQuestionText = CStr(rsQuiz.Fields("question_text").Value)
		' Get an array of answers
		aAnswers = Array( \_
		CStr(rsQuiz.Fields("answer_a").Value & ""), \_
		CStr(rsQuiz.Fields("answer_b").Value & ""), \_
		CStr(rsQuiz.Fields("answer_c").Value & ""), \_
		CStr(rsQuiz.Fields("answer_d").Value & ""), \_
		CStr(rsQuiz.Fields("answer_e").Value & ""), \_
		CStr(rsQuiz.Fields("answer_f").Value & ""))
		' This is probably bad coding style, but too bad... it works!
		For I = LBound(aAnswers) To UBound(aAnswers)
			If aAnswers(I) = "" Then
				ReDim Preserve aAnswers(I - 1)
				Exit For
		Next ' I
		rsQuiz.Close
		cnnQuiz.Close
	Else
		' BEGIN HARD CODE
		Select Case iQuestionNumber
			Case 1
				strQuestionText = "Vilken bollstorlek använder ni?"
					"Size 1", \_
					"Size 4", \_
					"Size 24", \_
					"Size 100", \_
					"Size 5", \_
					"Size 312")
			Case 2
				strQuestionText = "What command is \<%= %\> equivalent to?"
					"Response.Write", \_
					"Request.Write", \_
					"Referer.Write", \_
					"Redirect.Write", \_
					"Reasonably.Write", \_
					"Damn It I'm Right!")
			Case 3
				strQuestionText = "What does &quot;Option Explicit&quot; do?"
					"Requires explicit variable declaration", \_
					"Makes the computer give you additional errors", \_
					"Converts a PG rated programming language into one rated NC-17")
			Case 4
				strQuestionText = "Which of the following is not a valid "
				strQuestionText = strQuestionText & "VBScript looping statement?"
					"Do...Loop", \_
					"While...Wend", \_
					"For...Next", \_
					"For Each...Next", \_
					"Just do this 10 times you stupid computer!")
			Case 5
				strQuestionText = "What language can you not use to write ASP?"
					"VBScript", \_
					"JavaScript (JScript)", \_
					"PerlScript", \_
					"SuperScript")
			Case 6
				strQuestionText = "Where does ASP code execute?"
					"On the web server", \_
					"In the client's browser", \_
					"On any machine it wants to", \_
					"Reportedly somewhere in Washington State")
			Case 7
				strQuestionText = "Which set of acronyms is not associated with ASP?"
					"CDO, CDONTS", \_
					"ADO, RDS, DAO, ODBC", \_
					"IIS, PWS, MMC", \_
					"ADSI, XML", \_
					"B&Ouml;C, OU812, GNR, BTO")
			Case 8
				strQuestionText = "Which of the following is not something you can get "
				strQuestionText = strQuestionText & "from the Request collection?"
					"Cookies", \_
					"Form", \_
					"QueryString", \_
					"ServerVariables", \_
					"Beer", \_
					"ClientCertificate")
			Case 9
				strQuestionText = "What will this script output when run?\<BR\>\<BR\>\<%\<BR\>"
				strQuestionText = strQuestionText & "Dim aTempArray\<BR\>Dim I\<BR\>"
				strQuestionText = strQuestionText & "aTempArray = Array(1, 2, 3)\<BR\>"
				strQuestionText = strQuestionText & "For I = LBound(aTempArray) To "
				strQuestionText = strQuestionText & "Ubound(aTempArray)\<BR\>"
				strQuestionText = strQuestionText & "&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;"
				strQuestionText = strQuestionText & "Response.Write I & &quot&nbsp;&quot;\<BR\>"
				strQuestionText = strQuestionText & "Next 'I\<BR\>%\>\<BR\>"
					"0 1 2", \_
					"1 2 3", \_
					"0\<BR\>1\<BR\>2\<BR\>", \_
					"1\<BR\>2\<BR\>3\<BR\>")
			Case 10
				strQuestionText = "What is the URL of the best ASP web site?"
				aAnswers = Array("http://www.asp101.com (yeah... like we'd put any other choices here!)")
		End Select
		' END HARD CODE
	' Now that we've got the variables set...
	' show the appropriate question and choices
    \<FONT SIZE="+2"\>\<B\>\<%= Session("QuizName") %\>\</B\>\</FONT\>\<BR\>
    \<BR\>
    Svarsstapel:
	Const BAR_LENGTH = 160
	If iQuestionNumber = 1 Then
		' Since a 0 width is ignored by the browsers we need to remove the image altogether!
		Response.Write "\<IMG SRC=""./images/spacer_blue.gif"" HEIGHT=""10"" WIDTH="""
		Response.Write BAR_LENGTH
		Response.Write """\>\<BR\>"
	Else
		Response.Write "\<IMG SRC=""./images/spacer_white.gif"" HEIGHT=""10"" WIDTH="""
		Response.Write (BAR_LENGTH / iNumberOfQuestions) \* (iQuestionNumber - 1)
		Response.Write """\>"
		Response.Write (BAR_LENGTH / iNumberOfQuestions) \* (iNumberOfQuestions - (iQuestionNumber - 1))
    Fr&aring;ga\<%= iQuestionNumber %\> av\<%= iNumberOfQuestions %\>\<BR\>
    \<BR\>
    \<STRONG\>\<%= iQuestionNumber %\>.\</STRONG\>&nbsp;&nbsp;\<%= strQuestionText %\>\<BR\>
    \<BR\>
    \<STRONG\>Alternativ:\</STRONG\>
    \<OL TYPE="A"\>
	For I = LBound(aAnswers) to UBound(aAnswers)
		Response.Write "\<LI\>\<A HREF=""" & Request.ServerVariables("URL")
		Response.Write "?qid=" & iQuestionNumber & "&sa=" & I & """\>"
		Response.Write aAnswers(I) & "\</A\>\</LI\>" & vbCrLf
	Next 'I
    \</OL\>
End If 'bAbort
puh...
vad är problemet??
lite mer exakt :) (det är nog fler än jag som inte orkar läsa igenom denna kod)
ibland tror jag att jag kan lite för lite än vad jag kan ....
118 ms — deklarationer (db)
143 ms — hämta tråd, inlägg och bilagor (db)
117 ms — ändringar (db)
