Problem with load balancing
Webbutveckling
0 svar · 307 visningar · startad av jwc
Medlem sedan sep. 20081 inlägg
We need a load balancing setup that share the load for many web applications on multiple backend servers, but we don’t want the web apps to be activated on all backend servers at the same time. We want to configure all apps as “lazy” on all backend servers. They will then be activated when the first request to their DNS is made. Then the app is started on that backend server.
We have hundreds of apps and each backend server will become very slow if all apps are activated on all backend servers. The preferred solution would therefore be to not call all DNS names on all backend servers but to share the balance based on the DNS name in the requests. Sticky-session or sticky source-IP won’t be enough to solve this as they only stick to each user session.
If User-A request https://www.siteA.com he may be redirected to backend server 1 and then be kept there. But if User-B then requests the same https://www.siteA.com he may be redirected to backend server 2 and then be kept there. This means that the web application for siteA will be activated and loaded in both the backend servers. When we host hundreds of sites this will be a problem. We may have hundreds of backend servers but they will all end up loading all web apps over time and get out of memory.
The theory to get this work is a load balancer with the following logic:
1. A request for a certain DNS comes in. For example: https://www.siteA.com
2. Load balancer checks if this certain DNS has been redirected to a certain backend server before and if this server is alive
2.1. (If not redirected before): Redirect the request to the backend server with least load. Store the selected backend route based on the DNS name.
2.2. (If redirected before): Redirect the request to the assigned backend server for siteA.
3. If a backend server is down then all DNS requests to this server will be redirected to another backend server with least load. All requests to these DNS names will be assigned to this backend server instead.
Example of set up
Many DNS to one IP
192.168.1.1 https://www.siteA.com
192.168.1.1 https://www.siteB.com
192.168.1.1 https://www.siteC.com
Frontend load balancer
192.168.1.1 (load balancer)
Backend app servers
192.168.2.2 (App server 1)
192.168.2.3 (App server 2)
192.168.2.4 (App server 3)
Snapshot of servers during load
App server 1
https://www.siteA.com (Activated)
https://www.siteB.com (Lazy)
https://www.siteC.com (Lazy)
App server 2
https://www.siteA.com (Lazy)
https://www.siteB.com (Activated)
App server 3
https://www.siteC.com (Activated)
249 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
122 ms — deklarationer (db)
123 ms — ändringar (db)
