Amazon lanserar Glacier: långtidslagring / arkivering för $0,01 / GB / månad
Webbservrar
0 svar · 613 visningar · startad av Matti
Medlem sedan dec. 19996 592 inlägg
http://aws.amazon.com/glacier/
Amazon Glacier is an extremely low-cost storage service that provides secure and durable storage for data archiving and backup. In order to keep costs low, Amazon Glacier is optimized for data that is infrequently accessed and for which retrieval times of several hours are suitable. With Amazon Glacier, customers can reliably store large or small amounts of data for as little as $0.01 per gigabyte per month, a significant savings compared to on-premises solutions.
Companies typically over-pay for data archiving. First, they're forced to make an expensive upfront payment for their archiving solution (which does not include the ongoing cost for operational expenses such as power, facilities, staffing, and maintenance). Second, since companies have to guess what their capacity requirements will be, they understandably over-provision to make sure they have enough capacity for data redundancy and unexpected growth. This set of circumstances results in under-utilized capacity and wasted money. With Amazon Glacier, you pay only for what you use. Amazon Glacier changes the game for data archiving and backup as you pay nothing upfront, pay a very low price for storage, and can scale your usage up or down as needed, while AWS handles all of the operational heavy lifting required to do data retention well. It only takes a few clicks in the AWS Management Console to set up Amazon Glacier and then you can upload any amount of data you choose.
Det borde inte dröja alltför länge innan någon har gjort tjänsten lättanvänd för "vanliga" konsumenter. :-)
258 ms totalt · 4 externa anrop · v20260731065814-full.6fe65c25
126 ms — deklarationer (db)
127 ms — ändringar (db)
