Loopia och Gmail DNS
Webbhotell & domäner
3 svar · 935 visningar · startad av Dykarn
Medlem sedan mars 2005149 inlägg
Hej behover lite hjalp
ar helt ny i branchen nar det galler DNS
i allafall
jag skrev upp mig pa att testa gmails nya tjanst och behover nu lite hjalp med dns installningar
detta fick jag fran google
Procedures for changing MX records vary greatly from ISP to ISP. The instructions here are meant only as a general guide.
1. 	 Login to your ISP using the username and password associated with your domain.
2. 	Navigate to an MX record maintenance page. MX records are special DNS (Domain Name Service) records, and are often located under sections titled "DNS Management," "Mail Server Configuration," or "Name Server Management." You may need to turn on advanced settings to allow editing of these MX records.
3. 	Delete any existing MX records before entering new MX records.
4. 	For each MX record, enter information according to the entries in the following table.
You may not be allowed to enter the priority values exactly as they appear in the table below; in that case, simply ensure that the server addresses are prioritized in the same order as they appear in the table. (i.e. The priority ranking [1, 3, 3, 5, 5, 5, 5] should work just as well as [1, 5, 5, 10, 10, 10, 10] so long as you keep the addresses in the right order.)
If you're asked to specify the type of each record you're adding, enter "MX".
MX records often require the specific format of DNS records, including a trailing dot (".") at the end of any full-qualified domain names (e.g. "server.example.com.")
Set any TTL values to the maximum allowed.
MX Server address	           Priority
ASPMX.L.GOOGLE.COM.	          1
ALT1.ASPMX.L.GOOGLE.COM.	5
ALT2.ASPMX.L.GOOGLE.COM.	5
ASPMX2.GOOGLEMAIL.COM.	       10
ASPMX3.GOOGLEMAIL.COM.	       10
ASPMX4.GOOGLEMAIL.COM.	       10
ASPMX5.GOOGLEMAIL.COM.	       10
sa hur staller jag in detta hos loopia???
Inget svar på frågan men vad är det för ny tjänst gmail har som du ska testa ?
Medlem sedan juli 20011 084 inlägg
Du gör i princip som de skriver i sina punkter. Välj domänen, under e-postinställningar klickar man i "DNS" sedan får man välja MX-pekare enligt deras beskrivning.
126 ms — deklarationer (db)
118 ms — ändringar (db)
