Min Array skriver bara ut den första och den sista posten.
Här är koden
Det är den fetmarkerade texten jag tror problemet ligger i
Dim strPersonalCheck() As String
strPersonalCheck = SetPersonalID
con2 = True
row2 = 2
Do While con2 = True
value = Sheets(eventSheet2).Cells(row2, 1).value
If value <> "" Then
number2 = row2
title2 = Sheets(eventSheet2).Cells(number2, 1).value
startDate2 = DateValue(Sheets(eventSheet2).Cells(number2, 2).value)
endDate2 = DateValue(Sheets(eventSheet2).Cells(number2, 3).value)
persons2 = Sheets(eventSheet2).Cells(number2, 4).value
[B] strPersonal = Trim(persons2)
arrpersonal = Split(strPersonal, ",", -1, 1)
For Each strTemp In arrpersonal
strEnPersonal = strTemp
Do While startDate2 <= endDate2
DueDate2 = Format(startDate2, "yyyy-mm-dd")
personalPos = Application.Match(strEnPersonal, strPersonalCheck, False)
asd2 = insertInfo2(DueDate2, personalPos, title2)
startDate2 = DateAdd("d", 1, startDate2)
Loop
Next[/B]
Else
con2 = False
row2 = row2 + 1
Loop
End Sub
Function SetPersonalID() As String()
Dim con2 As Boolean
con2 = True
Dim number2 As Integer
number2 = 1
Dim value2 As String
Dim personalID() As String
value2 = Sheets(PersonalScheduleSheet).Cells(1, number2 + 1).value
If value2 <> "" Then
ReDim Preserve personalID(number2) As String
personalID(number2 - 1) = value2
Else
con2 = False
number2 = number2 + 1
Loop
SetPersonalID = personalID
End Function
Function insertInfo2(eventDate2, personalPos, title2)
Dim row2 As Integer
Dim con2 As Boolean
con2 = True
row2 = 2
value2 = CStr(Sheets(PersonalScheduleSheet).Cells(row2, 1).value)
If eventDate2 = value2 Then
con2 = False
Sheets(PersonalScheduleSheet).Cells(row2, personalPos + 1) = title2
ElseIf value2 = "" Then
con2 = False
row2 = row2 + 1
Loop
insertInfo2 = ""
End Function
Någon som ser vad jag gör för fel?
