Uppstart i Windows
2 svar · 976 visningar · startad av Lasp
Härförleden när vi var på resa upp i Sverige, tryckte jag på reset samtidigt åkte SD kortet ut i min Transonic Navigator och upp kom en liten meny i Windows :)stil!!
Det är Win-CE på GPSén men nu kan jag inte få till det igen. :(
Hur gör ma? :stud
Kontakta support?
>OveRRidE ! Tror inte det är en supportfråga :e
Detta har jag funnit så här långt:
Connect the device to your PC via active synch.
1 Move to the folder called \Mnav
2 Rename the mnavdce.exe to mnavdce_old.exe
3 Copy "regedit.exe" from the .zip file and paste into the \Mnav and rename it "mnavdce.exe
4 Copy "modified.reg" into the "Mnav" folder on the device
5 Soft reset your device
6 When the device reboots it will automatically launch Regedit. Click "File | Import" and then locate the "Mnav" folder in the files and folders selection list and double click to open. You will see the "modified.reg" file copied in step 4, double click to import.
7 Delete the renamed "regedit.exe (e.g. mnavedce.exe) in \mnav (or rename it)
8 Rename the "mnavdce_old.exe" back to "mnavdce.exe
9 Copy "showtaskbar.exe" from the .zip file and paste into \Windows\Startup
10 Locate "explore.exe" in the \windows folder, right click and select "Create Shortcut". Cut the "Shortcut to Explore.Exe" file that is created as a result and paste into \Windows\Desktop. Repeat this process for "MNAVDECE.exe located in the "Mnav" folder and "MP3Player.exe" located in \Windows
Finally reset your device once more with the stylus and it will boot to the WinCE desktop with shortcuts to the three applications you had before.
