Ett av sju stora matteproblem, P=NP?
Programmering
0 svar · 342 visningar · startad av hexadecimalen
Medlem sedan apr. 20057 inlägg
fran https://www.claymath.org
P vs NP Problem
Suppose that you are organizing housing accommodations for a group of four hundred university students. Space is limited and only one hundred of the students will receive places in the dormitory. To complicate matters, the Dean has provided you with a list of pairs of incompatible students, and requested that no pair from this list appear in your final choice. This is an example of what computer scientists call an NP-problem, since it is easy to check if a given choice of one hundred students proposed by a coworker is satisfactory (i.e., no pair from taken from your coworker's list also appears on the list from the Dean's office), however the task of generating such a list from scratch seems to be so hard as to be completely impractical. Indeed, the total number of ways of choosing one hundred students from the four hundred applicants is greater than the number of atoms in the known universe! Thus no future civilization could ever hope to build a supercomputer capable of solving the problem by brute force; that is, by checking every possible combination of 100 students. However, this apparent difficulty may only reflect the lack of ingenuity of your programmer. In fact, one of the outstanding problems in computer science is determining whether questions exist whose answer can be quickly checked, but which require an impossibly long time to solve by any direct procedure. Problems like the one listed above certainly seem to be of this kind, but so far no one has managed to prove that any of them really are so hard as they appear, i.e., that there really is no feasible way to generate an answer with the help of a computer. Stephen Cook and Leonid Levin formulated the P (i.e., easy to find) versus NP (i.e., easy to check) problem independently in 1971.
det problemet de tar upp tex. om alla mojliga svar maste genereras och sparas ar det int6e sjalvklart att det ar omojligt da?
det racker alltsa inte att bara generera ett svar sakart vilket ju ar jattelatt.
varfor skulle man egentligen behova generera allasvar? namn ett problem dar det behovs.
tetris ar val ett battre exempel isafall dar man kan se vilken losninge soma r bats(m,en nu verkar det ju inte ga).
skulle vara jattekul om nagon kunde forklara mer exakt vad man behover astadkomma for att problemet ska vara lost...
exemplet med studneterna har jag svart att se hur det kan goras snabbare eller battre, allt maste ju kollas, det ar val beta av som, galler?
finns det fler sidor om detta?
kan man se nagon programkod som forsoker los adet nagonstans kanse?
124 ms — deklarationer (db)
118 ms — ändringar (db)
