TButton
1 svar · 331 visningar · startad av Niclas Ohlsson
Niclas OhlssonMedlem sedan juli 200068 inlägg
Kan nån hjälpa mig med det här
//OBS!!!
//Man behöver 10 st TButton
unit Unit1;
interface
uses
Windows, Messages, SysUtils, Classes, Graphics, Controls, Forms, Dialogs,
StdCtrls;
type
TForm1 = class(TForm)
Button1: TButton;
Button2: TButton;
Button3: TButton;
Button4: TButton;
Button5: TButton;
Button6: TButton;
Button7: TButton;
Button8: TButton;
Button9: TButton;
Button10: TButton;
procedure Button1Click(Sender: TObject);
procedure Button3Click(Sender: TObject);
procedure Button4Click(Sender: TObject);
procedure Button5Click(Sender: TObject);
procedure Button6Click(Sender: TObject);
procedure Button7Click(Sender: TObject);
procedure Button8Click(Sender: TObject);
procedure Button9Click(Sender: TObject);
procedure Button10Click(Sender: TObject);
procedure Button2Click(Sender: TObject);
private
procedure Set_Ruta(Sender:TObject);
{ Private declarations }
public
{ Public declarations }
end;
var
Form1: TForm1;
implementation
procedure TForm1.Set_Ruta(Sender:TObject);
begin
//Vad ska det stå här om man vill att den
//knapp som man tryckte på ska
//flytta sig lite åt höger
end;
{$R *.DFM}
procedure TForm1.Button1Click(Sender: TObject);
begin
Set_Ruta(Sender);
end;
procedure TForm1.Button2Click(Sender: TObject);
begin
Set_Ruta(Sender);
end;
procedure TForm1.Button3Click(Sender: TObject);
begin
Set_Ruta(Sender);
end;
procedure TForm1.Button4Click(Sender: TObject);
begin
Set_Ruta(Sender);
end;
procedure TForm1.Button5Click(Sender: TObject);
begin
Set_Ruta(Sender);
end;
procedure TForm1.Button6Click(Sender: TObject);
begin
Set_Ruta(Sender);
end;
procedure TForm1.Button7Click(Sender: TObject);
begin
Set_Ruta(Sender);
end;
procedure TForm1.Button8Click(Sender: TObject);
begin
Set_Ruta(Sender);
end;
procedure TForm1.Button9Click(Sender: TObject);
begin
Set_Ruta(Sender);
end;
procedure TForm1.Button10Click(Sender: TObject);
begin
Set_Ruta(Sender);
end;
end.
jtMedlem sedan juni 2000350 inlägg
Du kan koppla samma onclick till alla knappar så slipper du massa procedurer.
Detta borde funka som svar på frågan.
if Sender is TButton then
TButton(Sender).Left := TButton(Sender).Left +10;
