När jag skall köra en javac på koden nedan, får jag följande fel:
C:\Andreas\Tomcat\webapps\ROOT\WEB-INF\classes>javac ParseXML.java
ParseXML.java:33: cannot resolve symbol
symbol : class ConnectionPool
ConnectionPool pool;
ParseXML.java:34: cannot resolve symbol
pool = new ConnectionPool();
2 errors
package lair.finance;
import lair.finance.*;
import java.sql.*;
import javax.sql.*;
import java.io.IOException;
import java.text.SimpleDateFormat;
import java.util.Calendar;
import java.util.Date;
import javax.xml.parsers.DocumentBuilderFactory;
import javax.xml.parsers.FactoryConfigurationError;
import javax.xml.parsers.ParserConfigurationException;
import javax.xml.transform.TransformerException;
import org.apache.xpath.XPathAPI;
import org.w3c.dom.Document;
import org.w3c.dom.Node;
import org.w3c.dom.NodeList;
import org.xml.sax.SAXException;
public class ParseXML
public ParseXML()
throws
SAXException,
IOException,
ParserConfigurationException,
FactoryConfigurationError,
Connection con = null;
String url = "http://www.ecb.int/stats/eurofxref/eurofxref-daily.xml";
Calendar cal = Calendar.getInstance();
cal.setTime(new Date());
cal.add(Calendar.DATE, -2);
String date = new SimpleDateFormat("yyyy-MM-dd").format(cal.getTime());
System.out.println("Date: " + date);
Document mDocument = DocumentBuilderFactory.newInstance().newDocumentBuilder().parse(url);
NodeList list =
XPathAPI.selectNodeList(mDocument, "Envelope/Cube/Cube[@time='" + date + "']/Cube");
for (int i = 0; i < list.getLength(); i++)
Node node = list.item(i);
String currency = node.getAttributes().getNamedItem("currency").getNodeValue();
String rate = node.getAttributes().getNamedItem("rate").getNodeValue();
System.out.println("currency=" + currency + ", rate=" + Double.valueOf(rate));
public static void main(String[] args) throws Exception
new ParseXML();
Meningen är att jag skall spara ner resultaten sen.
Andreas
