Applet problem
Javaur Java
1 svar · 204 visningar · startad av SannyW
SannyWMedlem sedan jan. 2003438 inlägg
Felmeddelande:
java.lang.UnsupportedClassVersionError: embe/ts/TeamStats (Unsupported major.minor version 8237.8195)
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at sun.applet.AppletClassLoader.findClass(Unknown Source)
at sun.plugin.security.PluginClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadCode(Unknown Source)
at sun.applet.AppletPanel.createApplet(Unknown Source)
at sun.plugin.AppletViewer.createApplet(Unknown Source)
at sun.applet.AppletPanel.runLoader(Unknown Source)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Några idéer, det har fungerat tidigare. Det funkar lokalt på min dator, men inte på servern. Har fungerad där tidigare, fattar ingenting.
Kan det vara på grund av att de ligger i olika kataloger?
data/
embe/
ViktorMedlem sedan aug. 20021 752 inlägg
kanske hjälper
It was due to mixup of classes compiled using JDK 1.4 and 1.3 ( and I
thought JDK 1.4 was backward compatible...)
To fix the problem, remove all the compiled classes (e.g. from the work
directoy of tomcat installation),
use the inbuilt JDK 1.3 that comes with WSAD. And do 'Rebuild All'.
Fast hoppa över WSAD och Tomcat, kör bara en omkompilering av alla filer.
/Viktor
130 ms totalt · 3 externa anrop · v20260731065814-full.29ac60f6
