Har lite krux med följande:
'Error
Note: sun.tools.javac.Main has been deprecated./sunjava.jsp:57: ')' expected.List convertTheEvents( List theListOfEvents ) ^/sunjava.jsp:100: Missing term.{ ^/sunjava.jsp:100: '}' expected.{ ^/sunjava.jsp:111: 'try' without 'catch' or 'finally'.}^/sunjava.jsp:115: Identifier expected. pageContext.write(_jsp_string1, 0, _jsp_string1.length);
^5 errors, 1 warning
'Koden
Vector vector = new Vector();
try {
BufferedReader bufferedReader = new BufferedReader( new StringReader( input ) );
String string = "";
while( ( string = bufferedReader.readLine() ) != null )
vector.addElement( string );
catch( IOException e ) {
// Kunde inte läsa
Object[] arrayen = vector.toArray();
Pattern DAY_DATE_PATTERN = Pattern.compile( "\\p{Alpha}+ (.*)" );
Pattern TIME_PATTERN = Pattern.compile( "\\d" );
Matcher dm = DAY_DATE_PATTERN.matcher("");
Matcher tm = TIME_PATTERN.matcher("");
String currentDate = "";
String nextItem;
for ( ListIterator iter = events.listIterator(); iter.hasNext(); )
nextItem = (String)iter.next();
// Let's find out if it is the dayDate format..
dm.reset( nextItem );
if ( dm.lookingAt() )
// then you found it...and YY-MM-DD is captured in group 1
currentDate = dm.group( 1 );
// get rid of it inside the list...you have the info you needed.
iter.remove();
// It must be the other kind (the time pattern).
tm.reset( nextItem );
if ( tm.lookingAt() )
// then you need to replace it
// with the correct format.
iter.set( currentDate + ' ' + nextItem );
// what the heck went on here???
System.out.println( "error in format: " + nextItem );
// now all the stuff in your List has the correct format.
// Do whatever you wanted to do with them.
return events;
// Here it is in action
String [] events =
for(int i = 0; i < arrayen.length; i++) {
out.println(arrayen[i]);
List better = convertTheEvents( Arrays.asList(events) );
for ( Iterator iter = better.iterator(); iter.hasNext(); )
System.out.println( iter.next() );
Har försökt klippa ut de rätta delarna från, som fungerar lysande.
http://test.myserverspy.com/test/help.txt
Men som sagt det är strul
Andreas
