Java ME Problem med record store
0 svar · 779 visningar · startad av nigge
niggeMedlem sedan feb. 2002199 inlägg
Tjena, jag försöker spara lite text mellan körningar.(text som ska sparas)
Jag har försökt använda den här koden men då läggs texten till men den sparas inte mellan körningarna... någon som vet vad som måste ändras?!
 * RMSDemo.Java
 * @author j2meSalsa.com
 * This class file shows you RMS Manipulations.
// Midlet class's package
import javax.microedition.midlet.*;
import javax.microedition.rms.*;
// Midlet's User interface API
import javax.microedition.lcdui.*;
public class RMSDemo extends MIDlet implements CommandListener {
	private Display display;
	// Commands
	private Command exitCommand = new Command("Exit", Command.EXIT, 1);
	private Command backCommand = new Command("Back", Command.EXIT, 1);
	private Command addCommand = new Command("Add Record", Command.EXIT, 1);
	// Record Store Obj's
	private RecordStore rs;
	private static final String rmsName = "salsaRMS";
	// Items for data capture and display
    private Form addForm;
    private TextField tfAddRecord;
    private Form showAllRecordsForm;
	private List enumList;
    // List for main menu
	private List mainList;
    private final String[] mainListArray = {
            "Add Record",
            "Show Records by Rec ID",
            "Show Records by Enumeration"
    private final Image[] imageArray = null;
  * Midlet constructor is called and the objects are instantiated.
  * Midlet enters paused state
    public RMSDemo() {
    	// Get MIDlets display handle
    	display = Display.getDisplay(this);
    	// Render Main List
        mainList = new List("Choose", Choice.IMPLICIT, mainListArray, imageArray);
        mainList.addCommand(exitCommand);
        mainList.setCommandListener(this);
        // Create Record Store
    	try {
    		rs = RecordStore.openRecordStore(rmsName, true );
    	}catch( RecordStoreException e ){
     * startApp() method is called to change the paused state to active state.
    protected void startApp() {
    	display.setCurrent(mainList);
     * The MIDlet frees as much resources as it can.
    protected void pauseApp() {}
     * Midlet cleans up resources before the application exits.
    protected void destroyApp(boolean bool) {}
     * Form to capture data to be inserted into Record Store.
    private void showAddRecordsForm() {
        addForm = new Form("Add Record");
        tfAddRecord = new TextField("Insert Text", "", 15, TextField.ANY);
        addForm.append(tfAddRecord);
        addForm.addCommand(addCommand);
        addForm.addCommand(backCommand);
        addForm.setCommandListener(this);
        display.setCurrent(addForm);
     * Form to display all records from Record Store by parsing via Record ID's.
    private void showAllRecordsForm() {
    	showAllRecordsForm = new Form("All Records");
    	int recordStoreSize=0;
    	int numRecords=0;
    	int totalRecords=0;
    	try{
    		recordStoreSize = rs.getSize();
    		numRecords = rs.getNumRecords();
    		totalRecords = rs.getNextRecordID() - 1;
    	}catch(Exception e){}
    	showAllRecordsForm.append("Record Store Size: " + recordStoreSize + " bytes"
    			+ "\nNumber of Records: " + numRecords
    			+ "\n...Contents...");
    	for( int id = 1; id <= totalRecords; id++ ){
    	    try {
    	    	byte[] data = new byte[rs.getRecordSize(id)];
    	    	data = rs.getRecord(id);
    	        showAllRecordsForm.append("Record #" + id + ": " + new String(data)  + "\n");
    	    } catch( Exception e ){
    	    	e.printStackTrace();
    	showAllRecordsForm.addCommand(backCommand);
    	showAllRecordsForm.setCommandListener(this);
    	display.setCurrent(showAllRecordsForm);
     * Form to display all records from Record Store by parsing via Enumeration.
    private void showEnumRecordsForm() {
        enumList = new List("Enumeration Demo", Choice.IMPLICIT);
    	try {
    		// Create Enumeration
			RecordEnumeration recEnum = rs.enumerateRecords( null, null, false );
			// Traverse the Enumeration to get get records.
			while( recEnum.hasNextElement() ){
				byte[] data = recEnum.nextRecord();
				enumList.append(new String(data), null);
			// Always destroy Enumeration
			recEnum.destroy();
		} catch (Exception e) {
		enumList.addCommand(backCommand);
		enumList.setCommandListener(this);
    	display.setCurrent(enumList);
     * Good ol' MIDlet event handling.
    public void commandAction(Command cmd, Displayable disp) {
        if (disp.equals(mainList)) {
            // In the main list
            if (cmd == List.SELECT_COMMAND) {
                    switch (((List)disp).getSelectedIndex()) {
                        case 0:
                            showAddRecordsForm();
                            break;
                        case 1:
                        	showAllRecordsForm();
                            break;
                        case 2:
                        	showEnumRecordsForm();
                            break;
        if (cmd == exitCommand) {
            destroyApp(false);
            notifyDestroyed(); // Midlet notifies the AMS that it has done its work.
        if ((cmd == backCommand) && (disp == addForm || disp == showAllRecordsForm || disp == enumList)) {
        if (cmd == addCommand) {
        	byte[] data = tfAddRecord.getString().getBytes();
            try {
            	int recordNo = rs.addRecord( data, 0, data.length);
            	display.setCurrent(new Alert("Insertion Status", "Record inserted at Record ID: " + recordNo, null, AlertType.CONFIRMATION) );
138 ms totalt · 3 externa anrop · v20260731065814-full.beb2e261
