Gnäller på variabel request
6 svar · 420 visningar · startad av jwradhe
jwradheMedlem sedan juni 2002711 inlägg
Hoho!
Har en javakod där jag försöker köra request.getParameter("NotToBeInovice");
men sen när jag försöker kompilera detta så gnäller den på variabel request.
protected String insertActionInDb(String prId, String userId, String[] to, String[] cc, String solution, String mail,String[] attachmentName, String actionType, String workHours, String workType) throws Exception {
	String sql = "select PersonId from CMCompanyPeople where WUIUserID='"+userId+"'";
	String[][] tab = rh.executeQuery(sql);
	String retInfo = null;
	String insertUser = "0";
	try {
		Double.parseDouble(workHours);
	} catch(Exception e) {
		workHours = "0";
	if (tab.length>0) {
		insertUser = tab[0][0];
	StringBuffer toInsert = new StringBuffer("Email sent to:\n");
	if(to != null) {
		for (int i=0; i<to.length;i++) {
			toInsert.append(to[i]);
			toInsert.append("\n");
	if(cc != null && cc.length>0) {
		toInsert.append("CC:\n");
		for (int i=0; i<cc.length;i++) {
			toInsert.append(cc[i]);
	if(attachmentName != null && attachmentName.length>0) {
		for (int i=0;i<attachmentName.length;i++) {
			if (attachmentName[i]!= null &&attachmentName[i].length()>0) {
				toInsert.append("Attached file: ");
				toInsert.append(attachmentName[i]);
	if (mail != null && mail.length() >0) {
		toInsert.append(mail);
	//toInsert.append("Solution/Status:\n");
	toInsert.append(solution);
	String insertString = toInsert.toString();
	if (insertString.length() > 2000) {
		retInfo = "The action text will be truncated<br>due to the long email text.";
		insertString = insertString.substring(0,2000);
	insertString = Util.escapeSingleQuotes(insertString);//Util.decode(insertString, 2));
	[B]String NotToBeInvoice = request.getParameter("NotToBeInovice");[/B]
	sql = "INSERT INTO [PRAction]( [PrId],[PersonId], [CustContactId],[ActionTypeId]"
	+",[CreationDate], [Description], [WorkHours], [WorkTypeId], [NotToBeInvoiced])"
	+" VALUES('" + prId + "','" +insertUser +"','0', '"+actionType+"', getDate(), '"+ insertString+"','"+workHours+"', '"+workType+"', '"+NotToBeInvoice+"')";
	Logging.logDebug(sql);
	rh.executeUpdate(sql);
	rh.executeUpdate("exec spInsertSOAPHeader 0," + prId + " ,0,1");
	return retInfo;
	protected InternetAddress[] parseEmailAddresses(String toParse) throws Exception{
		StringTokenizer strtoken = new StringTokenizer(toParse, ",");
		int iSize = strtoken.countTokens();
		InternetAddress[] retList = new InternetAddress[iSize];
		for(int i = 0; i < iSize; i++) {
			String tmpStr = strtoken.nextToken();
			tmpStr = tmpStr.trim();
			int pos = tmpStr.lastIndexOf(" ");
			String tmpName = "";
			String tmpAddress = "";
			if(pos == -1) { //Just an address if there exist an "@", otherwise just a name
				int atPos = tmpStr.indexOf("@");
				if(atPos == -1) { //Just a Name
					tmpName = tmpStr;
				} else { //Just an address
					tmpAddress = tmpStr;
			} else {
				if( tmpStr.indexOf("@") == -1 ) { //A name with space
					tmpName = tmpStr;
				} else {
					//There is both a name and an address.
					tmpAddress = tmpStr.substring(pos, tmpStr.length());
					tmpName = tmpStr.substring(0, pos);
			//At last remove potential "< >" from the address
			tmpName = tmpName.trim();
			tmpAddress = tmpAddress.trim();
			if(tmpAddress.indexOf("<") == 0) {
				tmpAddress = tmpAddress.substring(1, (tmpAddress.length()-1));
			retList[i] = new InternetAddress(tmpAddress, tmpName);
		return retList;
Nån aning om varför detta?
Vad ger den för fel, när den gnäller?
Har du importerat det paket som request finns i? Eller är det så att request kanske skall skickas med som parameter?
Jag har väldigt låg kunskap om java, så jag vet inte :) Inte jag som skrivit koden, utan ja ska endast lägga till ett värde i INSERT sql satsen.
Vart ser jag om det är importerat?
LimeMedlem sedan sep. 2001961 inlägg
Som jag ser det så finns inte request deklarerat någonstans i metoden insertActionInDb. Antingen måste du skicka med request-instansen till metoden eller så måste du göra den nåbar som ett attribut.
ahh ok :) ska försöka förstå vad det innebär :)
