SunixMedlem sedan juli 2004310 inlägg Hej!
Jag håller på att prova socketprogrammering i Java och har problem med trådar.
På klientsidan verkar det fungera med trådar men inte på serversidan.
Jag skulle bara vilja ha en enkel dos chatt.
CLIENTKOD:
import java.io.*;
import java.net.*;
public class Client
public static void main(String[] args)throws IOException
new SimpleThreadClient(1).start();
new SimpleThreadClient(2).start();
class SimpleThreadClient extends Thread {
private Socket smtpSocket = null;
private DataOutputStream os = null;
private DataInputStream is = null;
private BufferedReader in = null;
private String rcvLine, sendLine;
private int i;
public SimpleThreadClient(int i)throws IOException
this.i = i;
smtpSocket = new Socket("TomasM", 22222);
os = new DataOutputStream(smtpSocket.getOutputStream());
is = new DataInputStream(smtpSocket.getInputStream());
in = new BufferedReader(new InputStreamReader(System.in));
public void run()
while(true)
if(i==1)
try
sendLine = in.readLine();
os.writeBytes(sendLine + "\n");
catch (IOException e) {}
try
rcvLine = is.readLine();
System.out.println(rcvLine);
Jag har tagit bort lite kod men denna client fungerar
SERVERKOD:
import java.io.*;
import java.net.*;
public class Server
public static void main(String args[])throws IOException
ServerSocket echoServer = null;
Socket clientSocket = null;
echoServer = new ServerSocket(22222);
clientSocket = echoServer.accept();
is = new DataInputStream(clientSocket.getInputStream());
os = new DataOutputStream(clientSocket.getOutputStream());
while (true)
//new SimpleThreadServer(1,echoServer).start();
//new SimpleThreadServer(2,echoServer).start();
class SimpleThreadServer extends Thread {
private ServerSocket echoServer = null;
private Socket clientSocket = null;
private int i;
public SimpleThreadServer(int i, ServerSocket a)throws IOException
this.i = i;
//echoServer = new ServerSocket(22222);
echoServer = a;
public void run()
while(true)
if(i==1)
try
try
Jag använer inte simplethread i server p.g.a att det fungerar inte
Det jag vill är att tråda
så att server och client både lyssnar och sänder samtidigt
PS. Jag är nybörjare och har ingen felhantering eller nåt för att förstå lättare ds.
SunixMedlem sedan juli 2004310 inlägg Jaha ja! jag fixade det tillslut
KODSERVER:
import java.io.*;
import java.net.*;
public class Server
new SimpleThreadServerRcv(echoServer).start();
new SimpleThreadServerSend(echoServer).start();
class SimpleThreadServerRcv extends Thread {
public SimpleThreadServerRcv(ServerSocket socket)throws IOException
clientSocket = socket.accept();
public void run()
while(true)
try
class SimpleThreadServerSend extends Thread {
public SimpleThreadServerSend(ServerSocket socket)throws IOException
public void run()
while(true)
try
KODCLIENT
import java.io.*;
import java.net.*;
public class Client
new SimpleThreadClientSend().start();
new SimpleThreadClientRcv().start();
class SimpleThreadClientRcv extends Thread {
public SimpleThreadClientRcv()throws IOException
smtpSocket = new Socket("Localhost", 22222);
public void run()
while(true)
try
class SimpleThreadClientSend extends Thread {
public SimpleThreadClientSend()throws IOException
public void run()
while(true)
try
OBS! LÅNG I FRÅN PERFEKT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Nu är det bara att få det multiclient!
Ni får gärna hjälpa mig med det!!!!!!!!!!!!!!!!!! :birp
SunixMedlem sedan juli 2004310 inlägg Eller ..... ... ...... :OO
Det verkar som jag skapat 4 trådar. 2 i client och 2 i server.
Tråd1 i client = send
Tråd2 i client = recieve
Tråd1 i server = recieve
Tråd2 i server = send
Dessa verkar tillsammans om jag fattar det rätt
Tråd1 i client send kopplad mot Tråd1 i server recieve
Tråd2 i client recieve kopplad mot Tråd2 i server send
Men det måste finnas fler och myyycket bättre sätt!!
hjälp?
ps. Hmm är jag utmobbad på detta forum? Jag får aldrig några svar längre?! Gäller fler än denna tråd ds.
LimeMedlem sedan sep. 2001961 inlägg Sunix: Dina första inlägg postade mitt i natten. Vi som normalt jobbar på dagarna orkar inte alltid sitta uppe på nätterna för att svara på dina frågor inom en timme.
På dagtid jobbar iaf jag och då har jag inte mage att sno tid som mina kunder betalar för till att svara på frågor på wF.
För att sedan gå in på dina inlägg. Det saknas en problemställning. Vad är det du vill ha hjälp med? Som jag uppfattar det så ställer du frågor som du lättast får svar på genom att göra en tutorial i Socket-hantering. Finns ett par stycken bara på Javas hemsida.
För övrig har du fattat helt rätt. Tråd1 i client sänder och Tråd 2 tar emot.
Tråd 1 i server tar emot och Tråd 2 skickar. Runt runt...
Och enklare än så blir det inte... När du sedan börjar med Multisocket kommer du att göra samma sak men där kommer du att ha en send-tråd som skickar till alla de klient-sockets som anslutits till server och då blir det genast lite knepigare.
Fortsätt posta konkreta frågor så får du konkreta svar.
Jag menar egentligen hela webforum.nu. Förr fick man svar. Det får jag inte längre och då pratar jag om vecka/or. Fel av mig att säga detta just under java.
Tänk det visste inte jag !!!! Tack för att du talar om det! Gärna med någon bra länk eller nåt om du vill! Allt är ju frivilligt!
Jag tror det är detta jag personligen behöver. Lite feedback, eftersom jag inte riktigt kanske vet liksom. Och vidare lite tips kanske typ: "Om du gör så här så kommer det att fungera mycket bättre" typ.
Om nån vill (frivilligt igen).
Eftersom jag inte vet vad jag ska fråga specifikt så kan jag inte vara konkret, tror jag.
Konkret fråga tror jag:
Trådarna fungerar bara om ServerTråd1 är recieve och om ClientTråd1 är send.
Det funkar inte med ServerTråd1.recieve - ClientTråd2.send.
Varför?
Tack på förhand
