Syntaxproblem
9 svar · 264 visningar · startad av Bendro
BendroMedlem sedan jan. 20013 039 inlägg
Vid en uppdatering av mitt forum fick jag följande felmeddelande:
Microsoft OLE DB Provider for ODBC Drivers error '80040e09'
[MySQL][ODBC 3.51 Driver][mysqld-4.0.16-nt-log]You have an
error in your SQL syntax. Check the manual that corresponds to
your MySQL server version for the right syntax to use near '5
FORUM_FORUM.F_SUBJECT, FORUM_TOPICS.T_STATUS, FORUM_TOPICS.T_
/forum2/forum/My.asp, line 337
Koden felmeddelandet hänvisar till ser ut så här:
strSql = strSql & strTablePrefix & "FORUM.F_SUBJECT, " & strTablePrefix & "TOPICS.T_STATUS, "
strSql = strSql & strTablePrefix & "TOPICS.T_VIEW_COUNT, " & strTablePrefix & "TOPICS.FORUM_ID, "
strSql = strSql & strTablePrefix & "TOPICS.TOPIC_ID, " & strTablePrefix & "TOPICS.CAT_ID, "
strSql = strSql & strTablePrefix & "TOPICS.T_SUBJECT, "
strSql = strSql & strTablePrefix & "TOPICS.T_AUTHOR, " & strTablePrefix & "TOPICS.T_REPLIES, "
strSql = strSql & strMemberTablePrefix & "MEMBERS.M_NAME, " & strTablePrefix & "TOPICS.T_LAST_POST_AUTHOR, "
strSql = strSql & strTablePrefix & "TOPICS.T_LAST_POST, " & strMemberTablePrefix & "MEMBERS_1.M_NAME AS LAST_POST_AUTHOR_NAME "
strSql = strSql & "FROM " & strMemberTablePrefix & "MEMBERS, " & strTablePrefix & "FORUM, "
strSql = strSql & strTablePrefix & "TOPICS, " & strMemberTablePrefix & "MEMBERS AS " & strMemberTablePrefix & "MEMBERS_1 "
strSql = strSql & "WHERE " & strTablePrefix & "TOPICS.T_LAST_POST_AUTHOR = " & strMemberTablePrefix & "MEMBERS_1.MEMBER_ID  "
strSql = strSql & "AND " & strTablePrefix & "FORUM.FORUM_ID = " & strTablePrefix & "TOPICS.FORUM_ID "
strSql = strSql & "AND " & strTablePrefix & "FORUM.CAT_ID = " & strTablePrefix & "TOPICS.CAT_ID "
strSql = strSql & "AND " & strMemberTablePrefix & "MEMBERS.MEMBER_ID=" & id
strSql = strSql & "AND " & strTablePrefix & "TOPICS.T_AUTHOR=" & id
strSql = strSql & " ORDER BY " & strTablePrefix & "TOPICS.T_LAST_POST DESC;"
set rs = my_Conn.Execute (strSql)
Undrar om det är någon som ser vad det är felmeddelandet hänvisar till för syntaxfel?
Det saknas en del av sql-frågan. Det omnämns near '5 i meddelandet men någon 5:a finns ej med i din kod.
Gissar att du har
select top 5
någonstans!?
My bad...så här ser raderna precis ovanför ut:
if flag_maxtopics = 0 then
	strSql = "SELECT "
	strSql = "SELECT TOP " & flag_maxtopics & " "
top 5 är en icke standardkonstruktion som fungerar i MS-världen. Mysql har hittat på en egen syntax för detta
select ... from ...
order by ...
limt 5
Aha.. Bugar och tackar.
Nu har jag ändrat till:
'if flag_maxtopics = 0 then
	strSql = "SELECT "
	strSql = "SELECT "
strSql = strSql & " ORDER BY " & strTablePrefix & "TOPICS.T_LAST_POST LIMIT 5;"
Och får följande fel:
Microsoft OLE DB Provider for ODBC Drivers error '80040e14'
error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use
near 'FORUM_TOPICS.T_AUTHOR=1 ORDER BY FORUM_TOPICS.T_LAST_POST LIMIT
Skriv ut den färdiga SQL-frågan med response.write så blir det lättare att felsöka.
Er önskan är min lag:
SELECT FORUM_FORUM.F_SUBJECT,
FORUM_TOPICS.T_STATUS, FORUM_TOPICS.T_VIEW_COUNT,
FORUM_TOPICS.FORUM_ID, FORUM_TOPICS.TOPIC_ID,
FORUM_TOPICS.CAT_ID, FORUM_TOPICS.T_SUBJECT,
FORUM_TOPICS.T_AUTHOR, FORUM_TOPICS.T_REPLIES,
FORUM_MEMBERS.M_NAME, FORUM_TOPICS.T_LAST_POST_AUTHOR, FORUM_TOPICS.T_LAST_POST, FORUM_MEMBERS_1.M_NAME AS
LAST_POST_AUTHOR_NAME FROM FORUM_MEMBERS,
FORUM_FORUM, FORUM_TOPICS, FORUM_MEMBERS AS
FORUM_MEMBERS_1 WHERE
FORUM_TOPICS.T_LAST_POST_AUTHOR = FORUM_MEMBERS_1.MEMBER_ID AND FORUM_FORUM.FORUM_ID
= FORUM_TOPICS.FORUM_ID AND FORUM_FORUM.CAT_ID =
FORUM_TOPICS.CAT_ID AND FORUM_MEMBERS.MEMBER_ID=1AND FORUM_TOPICS.T_AUTHOR=1 ORDER BY
FORUM_TOPICS.T_LAST_POST LIMIT 5;
Det saknas ett mellanslag
Det skulle inte vara så dumt om du delade upp föregående inlägg i flera rader.
Sorry :r
Tänkte mig inte för.
136 ms totalt · 3 externa anrop · v20260731065814-full.457f92c7
134 ms — hämta forumlista (db)
