Problem med Request.QueryString
8 svar · 210 visningar · startad av Ralle
RalleMedlem sedan feb. 2003209 inlägg
Sasong2=Request.QueryString("Sasong2")
Set objConnect = Server.CreateObject("ADODB.Connection")
objConnect.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source= "& Server.MapPath("../databas/Ishockey.mdb")
strSQL1="SELECT DISTINCT Omgang AS Omg FROM Elitserien where Sasong=" & Sasong2 & ""
Set rstOmg = Server.Createobject("adodb.RecordSet")
rstOmg.Open strSQL1, objConnect, 1, 2
If rstOmg.EOF Then
     Response.Write("Ingen omgång funnen")
Else
     Response.Write("<Form name=""omgang"" action="""& Request.ServerVariables("SCRIPT_NAME") & """ method=""post"">")
     Response.Write("<SELECT name=""valdomgang"" OnChange=""this.form.submit();"">")
     Response.Write("<OPTION value=""x"">-- VÄLJ --</OPTION>")
     Response.Write("<OPTION value=0>Alla</OPTION>")
   Do until rstOmg.EOF
          Response.Write("<OPTION value=""" & rstOmg("Omg") & """>" &"Omgång " & rstOmg("Omg") & "</OPTION>")
          rstOmg.MoveNext
     Loop
     Response.Write("</SELECT>")
%><BR><BR><%
If request.form("valdomgang") <> "" then
valdomgang=request.form("valdomgang")
If Isnumeric(valdomgang) then
If valdomgang=0 Then
strSQL="SELECT Datum, Omgang, L1.Lag AS hemma, L2.Lag AS borta, HemmaPeriod1Mal, BortaPeriod1Mal, HemmaPeriod2Mal, BortaPeriod2Mal, HemmaPeriod3Mal, BortaPeriod3Mal, HemmaPeriod4Mal, BortaPeriod4Mal, HemmaPeriod5Mal, BortaPeriod5Mal FROM (Elitserien AS elit INNER JOIN Lag_i_Elitserien AS L1 ON L1.ID=elit.HemmaLag) INNER JOIN Lag_i_Elitserien AS L2 ON L2.ID=elit.BortaLag WHERE Sasong=" & Request.QueryString("Sasong2") & " ORDER BY Datum"
Set rstResultat=objConnect.Execute(strSQL)
Else
strSQL="SELECT Datum, Omgang, L1.Lag AS hemma, L2.Lag AS borta, HemmaPeriod1Mal, BortaPeriod1Mal, HemmaPeriod2Mal, BortaPeriod2Mal, HemmaPeriod3Mal, BortaPeriod3Mal, HemmaPeriod4Mal, BortaPeriod4Mal, HemmaPeriod5Mal, BortaPeriod5Mal FROM (Elitserien AS elit INNER JOIN Lag_i_Elitserien AS L1 ON L1.ID=elit.HemmaLag) INNER JOIN Lag_i_Elitserien AS L2 ON L2.ID=elit.BortaLag WHERE omgang=" & valdomgang & " AND Sasong1=" & Sasong2 & " ORDER BY Datum"
If rstResultat.EOF Then
Response.Write "Databasen är tom"
Värdet i "Sasong2" kommer från en länk som ser ut så här:localhost/Elitseriematcher.asp?Sasong2=2001-2002
När jag testar i Access frågor så fungerar det.
Kan någon se vad det kan vara för fel??
strSQL1="SELECT DISTINCT Omgang AS Omg FROM Elitserien where Sasong='" & Sasong2 & "'"
Tackar tackar, nu fungerar den biten bra.
Men jag har fortfarande problem när jag väljer med drop-listan.
Det verkar som värdet förvinner.
Någon som har en ide???
Vad menar du med att "värdet försvinner"?
När jag startar sidan så finns ju värdet från länken.
Men när jag väljer en omgång så försvinner slutet av länken, värdet verkar alltså försvinna.
Den startar om sidan, men utan slutet av länken.
blir:
Hoppas du förstår vad jag menar??
Den postar ju formuläret vid onchange, vilket innebär att den går till sidan som är angiven i action-attributet i <form>-taggen. Se till så querystringen hänger med i din action, så borde det inte vara några problem.
Jag fick hjälp med den här koden av en kille här, så jag är inte så bra på det.
Lite hjälp kanske??
Response.Write("<Form name=""omgang"" action="""& Request.ServerVariables("SCRIPT_NAME") [b]& "?Sasong2=" & Sasong2 & [/b]""" method=""post"">")
Tackar, nu fungerar det perfekt.
Genererad på 380 ms · cache AV · v20260730165559-full.f96bc7eb
