mysql och poster
3 svar · 193 visningar · startad av jboy_87
jboy_87Medlem sedan aug. 20011 105 inlägg
När jag försöker retunera alla poster i tabellen i control center så får jag följande felmess:
ERROR 1104: The SELECT would examine too many records and probably take a very long time. Check your WHERE and use SET OPTION SQL_BIG_SELECTS=1 if the SELECT is ok
jag har kollat i odbc inställningar och kryssat i Allow big results men funkar fortfarande inte?
:q
Såg följande
/* Quoted from someone nice:
He means :
1 - go to the far left window pane labeled ""MySQL Servers"
2 - right-click on the server name (mine is root@localhost:3306)
3 - select "Edit". This brings up a window with tabs, the 2nd of which
is
labeled "MySQL Options"
4 - On this tab is the option "Automatically limit SELECT queries to"
and
the default = 1. (WHO thought up this default?)
I set my limit to 10000, since some of my queries return more than 1000
records...
End quote. */
nähe den vill inte funka!
nu funka det när jag kryssa i Allow the use of bla bla
131 ms totalt · 3 externa anrop · cache AV · v20260731065814-full.56cc9887
