Hej detta script fungerar förträffligt bra för att återställa databasen på unix linux maskiner men jag får det ej att fungera under windows kan någon förklara varför ?
include "backup.php";
<html>
<title>phpMyBackup v.<? echo $version;?></title>
function restore(what) {
if (confirm("Are you sure you want to overwrite the database with the file " + what + "?")) {
window.location = "restore.php?file=" + what;
<body bgcolor="#FFFFFF" text="#000000">
<table width="100%" border="0" cellpadding="3">
<tr>
<td bgcolor="#DDDDDD" align="center"> <b><font face="Verdana, Arial, Helvetica, sans-serif">phpMyBackup
v.<? echo $version;?></font></b></td>
</tr>
</table>
<p align="center"><?
if ($file!="") {
$filename = $file;
set_time_limit(180);
if ($compression ==1) $file=gzread(gzopen($path.$file, "r"), 10485760);
else $file=fread(fopen($path.$file, "r"), 10485760);
$query=explode(";#%%\n",$file);
for ($i=0;$i < count($query)-1;$i++) {
mysql_db_query($dbname,$query[$i],$conn) or die(mysql_error());
echo "<b>$filename successfully restored!</b>";
?></p>
<div align="center">
<table border="0" cellpadding="5">
<tr align="center">
<td><u><i>File</i></u></td>
<td><u><i>Size</i></u></td>
<td><u><i>Date</i></u></td>
</tr>
$dir=opendir($path);
while ($file = readdir ($dir)) {
if ($file != "." && $file != ".." && eregi("\.sql",$file)) {
echo "<tr><td>$file </td>
<td align=\"right\"> " . bcdiv(filesize($path.$file),1024,1) . " kB </td>
<td> " . date("Y-m-d H:i",filemtime($path.$file)) . "</td>
<td> <a href=\"javascript:restore('$file')\"><b>Restore</b></a> </td>
<td> <a href=\"dump/$file\">View/Download</a></td> </tr>";
closedir($dir);
</table>
</html>
