sql = " select id, rubrik, detalj, user, privat"
sql = sql & " FORMAT$(datum, 'yyyy-mm-dd') as datum1,"
sql = sql & " FORMAT$(frantid, 'hh:mm') as ftid,"
sql = sql & " FORMAT$(tilltid, 'hh:mm') as ttid"
sql = sql & " from plan"
sql = sql & " where id = " & iId
[b] line 46--> [/b]Set RS = Conn.Execute(sql)
Och jag får felmeddelandet:
Microsoft JET Database Engine error '80040e14'
Syntax error (missing operator) in query expression 'privat FORMAT$(datum, 'yyyy-mm-dd')'.
/edit.asp, line 46
Vad kan detta bero på?
