Har problem med att få fupload att fungera.
Vill använda detta för att ladda bilder till en MySQL-bas som består av fälten:
BLOB_ID tinyint
BLOBa longblob
Får felmeddelandet: Exception when loading BLOB field.
Anväder följande kod:
<%@LANGUAGE="VBSCRIPT"%>
<HTML>
<HEAD>
<TITLE>File Upload Test</TITLE>
</HEAD>
<BODY>
<BR>
<BR>
<CENTER>
If Request.querystring("Status") = 1 Then
Set oUpload = Server.CreateObject("ASPPW.Upload")
'oUpload.UserDiskQuota= 20 * 1024 * 1024
oUpload.RejectEmptyExtension = No
oUpload.FileExtensionList "txt", "gif" ,"jpg", "*" 'remove '*', if you don't allow all types
oUpload.RegistrationCode = ""
oUpload.RemoveUploadedFilesOnError = YES
'Save uploaded file here.
'oUpload.UpLoadPath =
'Uncomment following lines to save files with a prefix or suffix
'for example, saving abc.gif as Prefix_abc_Suffix.gif.
'oUpload.SaveFileWithPrefix="Prefix_"
'oUpload.SaveFileWithSuffix="_Suffix"
'Uncomment following lines to upload a file into a BLOB field.
'Note: BLOB uploading doesn't support uploading multiple files
' at a single time.
' Microsoft ADO is required.
oUpload.BLOBFieldName = "BLOBa"
oUpload.LoadIntoBLOBOnly = True
oUpload.BLOBSQL ="SELECT BLOBa FROM BLOB_TBL WHERE BLOB_ID=1"
oUpload.CONNECTIONSTRING= "driver=MySQL;DB=namn på basen;SERVER=server.se;UID=admin;PWD=12345678"
i = oUpload.Upload
Select Case i
case 1
sMsg = "File uploading ends normally."
Case -4
sMsg = "User's disk quota full."
Case -5
sMsg = "Path on server for uploading not found or invalid."
Case -6
sMsg = "A file type for uploading is not allowed."
Case -7
sMsg = "Uploading exception."
Case -8
sMsg = "File access failure." 'Check your NTFS directory permission, Add R/W/D to IUSR_xxx
Case -9
sMsg = "Bad Content Header."
Case -11
sMsg = "Exception when loading BLOB field."
case else
sMsg = "Exception. Error Code is: " & i & "."
End Select
Response.write "<H1>" + sMsg + "</H1>"
If oUpload.GetLastErrNum <> 0 Then
Response.write "Error: " & oUpload.GetLastErrDescription & "<BR>"
End if
Response.write CStr(oUpload.NumofUploadedFiles) + " file(s) uploaded. "
If oUpload.LoadIntoBLOBOnly = false Then
Response.write CStr(oUpload.UserDiskSpaceLeft) + " bytes left for more uploading.<BR>"
End if
Set oForm = oUpload.Form 'return a Collection
Set oFiles = oUpload.UploadedFileInfo 'return a Collection
'response.write oFiles.count 'Sample operation to a collection
'Set item = oFiles.item(1) 'Sample operation to a collection
<table width="100%" border="1">
<tr>
<td nowrap>Uploaded File's Name</td>
<td nowrap>Uploaded File's Length</td>
<td nowrap>FORM Item Name</td>
<td nowrap>(Optional) Caption</td>
<td nowrap>Client Side Path</td>
</tr>
<% for each file in oFiles %>
<tr>
<td nowrap><%=file.filename%></td>
<td nowrap><%=file.filelen%></td>
<td nowrap><%=file.formname%></td>
<td nowrap><%=oForm(file.formname)%></td>
<td nowrap><%=file.clipath%></td>
</tr>
<% next %>
</table>
<% 'Another demo
Set file = oFiles("uplfile1")
if file.filename <> "" then
response.write oFiles("uplfile1").formname & ": "
response.write file.filename & " "
response.write CStr(file.filelen) & " bytes "
response.write oForm(file.formname) & "<br>"
Set file = nothing
'It is easy to delete the uploaded stuff.
'if oFiles.Count >0 then oUpload.DeleteFile server.mappath("/") & "\test\" & oFiles(1).filename
'oUpload.DeleteDir server.mappath("/") & "\test"
Set oFiles = nothing
'Following codes show you how you how to fetch <FORM> items.
'This COM component uses the BinaryRead method, thus
'you can not fetch form items by using request.form("What").
'According to Microsoft IIS document, this will cause an error.
<p>
<H2>Demonstration of fetching form items: </H2>
<!-- Method 1 -->
response.write "oForm(""Org_Code"").value: " & oForm("Org_Code").value
'response.write "oForm(""Org_Code"").value: " & oForm("Org_Code") 'Same as above
'Set item = oForm("Org_Code")
'Response.write item.value
<!-- Method 2 -->
<table width="80%" border="1">
<tr>
<td>Form Item Name</td>
<td>Form Item Value</td>
</tr>
<% for each item in oForm %>
<tr>
<td><%=item.name%></td>
<td><%=item.value%></td>
</tr>
<% next %>
</table>
Set oForm = nothing
Set oUpload = nothing
End if
<FORM NAME=up ACTION="fupload.asp?Status=1" METHOD="POST" ENCTYPE="multipart/form-data">
<!-- You can specify the filenames for uploaded files as below
ServerName1 ...99
<FORM NAME=up ACTION="fupload.asp?Status=1&ServerName1='aa 1.gif'&ServerName2='bb 2.gif'" METHOD="POST" ENCTYPE="multipart/form-data">
<H1>Upload Files</H1>
<BR>
<!-- Remove below form item if you don't need it. -->
<INPUT TYPE=HIDDEN SIZE=36 NAME="Org_Code" VALUE="Research Dept.">
<!-- Remove above form item if you don't need it. -->
<INPUT TYPE=HIDDEN SIZE=36 NAME="uplfile1" VALUE="From Research Dept.">
<!--INPUT TYPE=HIDDEN SIZE=36 NAME="uplfile2" VALUE="From Development Dept.">
<INPUT TYPE=file SIZE=36 NAME="uplfile1">
<!-- ServerName1 -->
<P>
<!-- You can add more if you want to upload more files at a single time -->
<INPUT TYPE=SUBMIT NAME="SUBMIT" VALUE=" Upload ">
<p align="right"><a href="http://www.dalun.com"><font face="Verdana, Arial" size="1">Dalun
Software, Inc. </font></a>
</FORM>
</CENTER>
</BODY>
</HTML>
Mycket tacksam för svar!
