Vad innebär det här felet?
Warning: mysql_db_query is deprecated; use mysql_select_db() and mysql_query() instead in C:\Inetpub\wwwroot\cgi-bin\sqltest\index.php on line 6
Warning: mysql_db_query is deprecated; use mysql_select_db() and mysql_query() instead in C:\Inetpub\wwwroot\cgi-bin\sqltest\index.php on line 9
Jag körd den här koden:
<?php
$open = mysql_connect("localhost", "Andreas");
$dbinfo = mysql_db_query("test", "INSERT tabell (namn) VALUES ('Pelle')");
$data = mysql_db_query("test", "SELECT * FROM tabell ORDER BY namn");
while ($rad = mysql_fetch_array ($data)) {
print "<B>";
print $rad["namn"];
print "</B><P>";
mysql_close($open);
Vad är fel :q
Schöndells webbsajt
