Importera databaser/tabeller?
5 svar · 422 visningar · startad av OlleBoop
OlleBoopMedlem sedan feb. 20001 861 inlägg
Hej.
Går det att importera en accessdatabas i MySQL?
Går det att göra tvärt om?
En bra länk angående flytt av databaser i allmänhet(inte bara MySQL/Access-specifikt)?
/Adam
RyzzenMedlem sedan mars 2000267 inlägg
En kod snutt jag hittade för ett tag sedan..
<?php
 * This include file defines the functions html_header and html_footer
require( "design.inc");
$mysqldb =  "concord";
function nonfatal_error($message)
    printf( "<H1>%s</H1>\n",$message);
function upload_records($odbcfd,$myfd,$mysqldb,$table)
* Figure out which columns the mysql database has
    $fieldlist = mysql_list_fields($mysqldb,$table);
    $numof  = mysql_num_fields($fieldlist);
    for($i = 0; $i < $numof; $i++)
        $fieldname = mysql_field_name($fieldlist,$i);
        if($i == 0)
            $columnlist = $fieldname;
            $columnlist = $columnlist .  "," . $fieldname;
        $fieldtype = mysql_field_type($fieldlist,$i);
        switch($fieldtype)
        case  "string":
        case  "datetime":
            $fieldquotes[$fieldname] =  "'";
            break;
        default:
            $fieldquotes[$fieldname] =  "";
            break;
* Query the ODBC database and loop through the result.
    $res = odbc_exec($odbcfd, "SELECT * FROM $table");
    if($res == 0)
        nonfatal_error( "Couldn't exec SELECT statement on ODBC database");
        return(0);
* Now we know we can query the ODBC database we can delete the records from
the Mysql
* database
    mysql_db_query($mysqldb, "DELETE FROM $table",$myfd);
    $rowinx = 0;
    while(odbc_fetch_row($res))
* Generate the SQL INSERT STATEMENT
            if($i == 0)
                $vallist = $fieldquotes[$fieldname] .
                   addslashes(odbc_result($res,$fieldname)) .
                   $fieldquotes[$fieldname] ;
                $vallist = $vallist .  "," . $fieldquotes[$fieldname] .
        $cmd =  "INSERT INTO $table ($columnlist) VALUES ($vallist)";
    if($rowinx % 10 == 0)
        echo  "<br>";
    printf( "%06s\n",$rowinx);
        if(mysql_db_query($mysqldb,$cmd,$myfd) == 0)
            nonfatal_error(mysql_error());
        $rowinx++;
    return(1);
* Start of the program
* Connect to the MySQL server
$myfd = mysql_connect( "atilia", "guest", "xxxx");
if($myfd <= 0)
    nonfatal_error( "Couldn't open MySQL database");
    exit($myfd);
* Connect to the ODBC ressource.
* The DSN must be defined in the executing computer's ODBC tables
$odbcfd = odbc_connect( "ConcAccess", "x", "e");
if($odbcfd <= 0)
    nonfatal_error( "Couldn't open ODBC database");
    exit($odbcfd);
function list_tables($mysqldb)
    echo  "<UL>\n";
    $tables= mysql_list_tables($mysqldb);
    for($i = 0; $i < mysql_num_rows($tables);$i++)
        printf( "<LI>Upload table <A HREF=\"upload.php3?table=%s\">%s</A>\n",
            mysql_tablename($tables,$i),
            mysql_tablename($tables,$i));
    echo  "</UL>\n";
switch ($table)
case  "":
    html_header( "Update Database on mysql");
<P>This page allows you to upload tables from the MS-Access database to the
database
on the webserver. There <I>might</I> be some uploading errors. This is the
reason
you can only upload one table at a time. You should select a table and then
look at the
result for errors.</P>
<?php
    break;
default:
    html_header( "Uploading $table");
    echo ( "Row ## Row ## Row ## Row ## Row ## Row ## Row ## Row ## Row ##
Row ##<br>\n");
    $dotable=0;
    for($i = 0; $i < mysql_num_rows($tables); $i++)
        if(mysql_tablename($tables,$i) == $table)
             $dotable=1;
    if($dotable == 1)
        upload_records($odbcfd,$myfd,$mysqldb,$table);
        nonfatal_error( "There was no such table");
    break;
odbc_close($odbcfd);
mysql_close($myfd);
html_footer();
Kan kanske hjälpa dej en bit på vägen..
'hanx Ryzzen! = )
/Adam
Det är bara att sätta upp en ODBC-koppling til MySQL på PC:n, och exportera till ODBC från Access. Du får mickla lite med räknare och nycklar, men det går toksmidigt.
Tack!
PatrikBMedlem sedan mars 20002 836 inlägg
Hello,
kolla in denna länk
scrolla ned en bit och kolla under converters. finns en massa "verktyg" där för att konvertera access (å andra db) till mySQL.
cya
//PatrikB
** ZWGdesign **
