avancerad ORDER BY ?
2 svar · 226 visningar · startad av Gein
GeinMedlem sedan sep. 20005 700 inlägg
går det att köra en ORDER BY (summa2 - summa1) på något sätt? alltså subtrahering(stava?) :D
"When there's no more room in hell,
the dead will walk the earth."
--------------------- http://shortenings.cjb.net
[Redigerat av puzze den 10 feb 2002]
tohaMedlem sedan dec. 1999707 inlägg
Uhm, nej det går nog inte. Vet nog inte riktigt vad du tänker på att du vill åtstadkomma men order by syftar på ett, eller flera fält.
ORDER BY
Syntax
[ ORDER BY { order_by_expression [ ASC | DESC ] } [ ,...n] ]
Arguments
order_by_expression
Specifies a column on which to sort. A sort column can be specified as a name or column alias (which can be qualified by the table or view name), an expression, or a nonnegative integer representing the position of the name, alias, or expression in select list.
Multiple sort columns can be specified. The sequence of the sort columns in the ORDER BY clause defines the organization of the sorted result set.
The ORDER BY clause can include items not appearing in the select list. However, if SELECT DISTINCT is specified, or if the SELECT statement contains a UNION operator, the sort columns must appear in the select list.
Furthermore, when the SELECT statement includes a UNION operator, the column names or column aliases must be those specified in the first select list.
/ Torbjörn Hansson, Barium
puzze, har du testat innan du frågar... ;)
Ze mor aj kåmmjonikejt wiz pipol ze mor i lörn.
142 ms totalt · 3 externa anrop · v20260731065814-full.30151723
