Panikfråga
1 svar · 210 visningar · startad av Bendro
Medlem sedan jan. 20013 039 inlägg
Sitter och pluggar SQL och har fått en uppgift. Har letat efter svaret i Transact-SQL hjälpen och även i den enda bok jag har tillgänglig men hittar det inte där.
Frågan är "Vad är en CHECK-constraint?"
Finns det någon som kan ge mig ett bra svar eller kan tala om för mig var jag skall leta vore jag evigt tacksam.
"You can not solve todays problems with the same level of thinking that created the problems in the first place" Albert Einstein
Medlem sedan juni 200032 969 inlägg
hej!
kort kan man säga att du begränsar tillåtna värden i en kolumn.
nedan på engelska ur sql server 7.0 books on line.
mvh,
CHECK constraints enforce domain integrity by limiting the values that are accepted by a column. They are similar to FOREIGN KEY constraints in that they control the values that are placed in a column. The difference is in how they determine which values are valid: FOREIGN KEY constraints get the list of valid values from another table, and CHECK constraints determine the valid values from a logical expression that is not based on data in another column. For example, it is possible to limit the range of values for a salary column by creating a CHECK constraint that allows only data that ranges from $15,000 to $100,000. This prevents salaries from being entered beyond the normal salary range.
You can create a CHECK constraint with any logical (Boolean) expression that returns TRUE or FALSE based on the logical operators. For the previous example, the logical expression is:
salary >= 15000 AND salary <= 100000
It is possible to apply multiple CHECK constraints to a single column. These are evaluated in the order in which they were created. It is also possible to apply a single CHECK constraint to multiple columns by creating it at the table level. For example, a multiple-column CHECK constraint can be used to confirm that any row with a country column value of USA also has a two-character value in the state column. This allows multiple conditions to be checked in one place.
if i'm not back in five minutes, just wait longer.</A>
129 ms totalt · 3 externa anrop · v20260731065814-full.55e59744
