No value given for one or more required parameters.
3 svar · 347 visningar · startad av preben
Medlem sedan mars 2009452 inlägg
SQL = "SELECT a.intID, a.strName FROM [article] a, [articleCounter] ac WHERE a.intID = ac.intArticleID " _
	& " AND DATEPART(month, ac.dteCreated) = " & month(date()) & " AND DATEPART(year, ac.dteCreated) = " & year(date()) _
	& " ORDER BY ac.intCounter DESC;"
Jag kör klassisk ASP + Access och det är nåt som inte stämmer med datumraden. Men vad!?
Utskriven ser koden ut så här:
= ac.intArticleID AND DATEPART(month, ac.dteCreated) = 11 AND
DATEPART(year, ac.dteCreated) = 2009 ORDER BY ac.intCounter DESC;
SELECT * FROM [articleCounter] ac WHERE DATEPART(month, ac.dteCreated) = 11;
Inte heller denna fungerar...:
SQL = "SELECT * FROM  [articleCounter] ac  WHERE  DATEPART('mm', ac.dteCreated) = 11;"
OK, jag svarar mig själv här. The answer is... enkelfjumpar!
Tack!
Bra tutorial: http://www.tizag.com/sqlTutorial/sqldatepart.php
Sökte efter datePart i detta forumet.
Fel av mig... Igen.
' ## TOP 5 MOST READ ARTICLES PER EACH MONTH
SQL = "SELECT a.intID, a.strName, ac.intCounter FROM [article] a, [articleCounter] ac WHERE a.intID = ac.intArticleID " _
	& " AND month(ac.dteCreated) = " & month(date()) & " AND year(ac.dteCreated) = " & year(date()) _
'	response.write SQL
set mySQL = Conn.Execute(SQL)
IF NOT mySQL.EOF THEN listMyTOP5List = mySQL.GetRows()
Så här ska det vara i Access!
136 ms totalt · 3 externa anrop · v20260731065814-full.25f56b17
