Group By - eller?
1 svar · 370 visningar · startad av Bjuris
BjurisMedlem sedan juli 2001514 inlägg
Jag blir inte riktigt klok.
Har en tabell enl:
AnswerID |ReportID | StudentID | BaseID | GoalID | Answer | osv...
en sp:
ALTER PROCEDURE tuser887.GetSavedBaseByStudentID @StudentID uniqueidentifier
AS
	Select answerId, reportId, studentId, Base.BaseName, Topic.TopicName,  answers.GoalId, Answer, Comment, [TimeStamp], CreatedBy,
	sum(case when Answer = 0 then 1 else 0 end) as iGreen,
	sum(case when Answer = 1 then 1 else 0 end) as iOrange,
	sum(case when Answer = 2 then 1 else 0 end) as iRed,
	as totalQuestions
	from MyPlan_Answers AS Answers
	Left Outer JOIN MyPlan_Base AS Base
	ON Base.BaseId = Answers.BaseId
	Left Outer JOIN MyPlan_Goal AS Goal
	ON Goal.GoalId = Answers.GoalId
	Left Outer JOIN MyPlan_Topic AS Topic
	ON Topic.TopicId = Goal.TopicId
	Where studentId = @StudentID
	Group BY CreatedBy, answerId, reportId, studentId, Base.BaseName, Topic.TopicName,  answers.GoalId, Answer, Comment, [TimeStamp], Base.BaseId
	Order by createdBy, Base.Basename, Topic.TopicName
RETURN
Denna returnerar en rad för varje post
ex:
Admin - 3 - Slöjd - 1 iGreen - 0 iOrange - 0 iRed
Admin - 3 - Slöjd - 0 iGreen - 1 iOrange - 0 iRed
Admin - 3 - MA- 1 iGreen - 0 iOrange - 0 iRed
osv
Men jag vill att det skall hämtas ut en rad per | Admin - 3 - slöjd | samt summera antal iGreen - summera antal iOrange - summera antal iRed
ex:
Admin - 3 - Slöjd - 1 iGreen - 1 iOrange - 0 iRed
Admin - 3 - MA- 2 iGreen - 0 iOrange - 0 iRed
Hur skall jag göra?
never mind.
löste felet.
AS
	Select Base.BaseName, Topic.TopicName, CreatedBy,
	(SELECT  COUNT(*) FROM MyPlan_Goal i WHERE  i.BaseId = Base.BaseId and i.TopicId = Topic.TopicID) as totalQuestions
	Group BY CreatedBy, Base.BaseName, Topic.TopicName, Base.BaseId, Topic.TopicId
RETURN
127 ms totalt · 3 externa anrop · v20260731065814-full.0e50b1ef
