Om nåt värde är tomt, ändå visa resten.
Databaser & SQL
5 svar · 477 visningar · startad av jwradhe
Medlem sedan juni 2002711 inlägg
Hej! Jag håller på med en sql sökning, där ja ska ha ut massor av värden.
Ifall alla i ifyllda funkar det kanon, men om nåt värde är NULL tex, så skiter sig hela koden och allt blir tomt.
hur löser jag detta? Hittade inget direkt när jag sökte.
select
PRHeaderTemplate.Title,
PRHeaderTemplate.Description,
PRHeaderTemplate.foreignid,
PRHeaderTemplate.Origin,
PRHeaderTemplate.Erranddescription,
PRHeaderTemplate.Impact,
PRHeaderTemplate.Solutions,
PRHeaderTemplate.Downtime,
PRHeaderTemplate.Duedate,
PRHeaderTemplate.MinRegTime,
CMProducts.ProductName,
PRType.PRTypeName,
PRSeverityType.Description,
CMCountry.Country as CountryName,
CMCompanies.CompName,
Responsible.Name as ResponsibleName,
Assigned.Name as AssignedToName,
PRStatusType.Description,
PRSourceType.SourceName,
PRErrorTypes.ErrorName,
CMProductsVersions.Version,
PRApps.AppName,
CMProcess.ProcessName,
PRInvoiceStatus.InvoiceStatusName,
CMWorkType.WorkTypeName,
reportedbyperson.Name
from
PRHeaderTemplate
INNER JOIN PRType ON PRHeaderTemplate.PRTypeId = PRType.PRTypeID
INNER JOIN PRSeverityType ON PRHeaderTemplate.SeverityId = PRSeverityType.SeverityId
INNER JOIN CMCountry ON (SELECT CountryID from CMCompanies where compid = PRHeaderTemplate.invoicecompany) = CMCountry.CountryId
INNER JOIN CMCompanies ON PRHeaderTemplate.invoicecompany = CMCompanies.CompId
INNER JOIN CMCompanyPeople AS Responsible ON PRHeaderTemplate.ResponsiblePersonId = Responsible.PersonId
INNER JOIN CMCompanyPeople AS Assigned ON PRHeaderTemplate.AssignedToPersonId = Assigned.PersonId
INNER JOIN CMProducts ON PRHeaderTemplate.ProdId = CMProducts.Prodid
INNER JOIN PRStatusType ON PRHeaderTemplate.StatusId = PRStatusType.StatusId
INNER JOIN PRSourceType ON PRHeaderTemplate.SourceId = PRSourceType.SourceId
INNER JOIN PRErrorTypes ON PRHeaderTemplate.ErrorTypeId = PRErrorTypes.ErrorTypeId
INNER JOIN CMProductsVersions ON PRHeaderTemplate.ProductVersionId = CMProductsVersions.ProductVersionId
INNER JOIN PRApps ON PRHeaderTemplate.AppId = PRApps.Appid
INNER JOIN CMProcess ON PRHeaderTemplate.processid = CMProcess.ProcessId
INNER JOIN PRInvoiceStatus ON PRHeaderTemplate.invoicestatusid = PRInvoiceStatus.InvoiceStatusId
INNER JOIN CMWorkType ON PRHeaderTemplate.worktypeid = CMWorkType.WorkTypeId
INNER JOIN CMCompanyPeople AS reportedbyperson ON PRHeaderTemplate.reportedby = reportedbyperson.PersonId
where PRHeaderTemplate.Id = '16'
Medlem sedan maj 20012 237 inlägg
Pröva med LEFT OUTER JOIN
Jag är inget proffs på SQL, har bara lärt mig inner join ännu, va gör den för skillnad?
eller måste ja googla mig fram till det ;)
jag hittade min förklaring på hur dom skilljer sig, tack för tipset!
http://iwtjanster.idg.se/webbstudio/pub/artikel.asp?id=76
En annan fråga som kanske inte helt har med detta att göra, är att jag tar ju where id = nåt id, idt skickas i länken från sidan innan, och just nu har jag ett värde hela tiden, men om jag vill ha sidan med detta script uppe från början, och inte har nåt värde, hur fasen ska jag göra då?
I sidan som visar upp resultatet har du en koll, om ID är angivet, använd det, annars använd ett default-värde. Typ?
126 ms — deklarationer (db)
126 ms — ändringar (db)
