Snabba upp sql-fråga
5 svar · 371 visningar · startad av Addeladde
AddeladdeMedlem sedan jan. 20013 406 inlägg
Hej
Jag har en sql-fråga som är skriven för Sybase SQL-Anywhere 9 som ser ut enligt följande:
SELECT AN.PERSONID, A.GRUPP FROM AKTIVITET AS A
LEFT JOIN GRUPP AS G ON A.GRUPP = G.GRUPP
LEFT JOIN KURS AS K ON G.KURS = K.KURS
LEFT JOIN ANSTALLNING AS AN ON A.SIGNBETYG = AN.SIGN
LEFT JOIN UTBILDNING AS U ON A.PERSONID = U.PERSONID
WHERE A.ENHET = 'XX'
AND U.ENHET = 'XX'
AND (U.STOPPDATUM IS NULL OR U.STOPPDATUM > GETDATE())
AND A.STARTDATUM <= GETDATE()-10
AND A.STOPPDATUM >= GETDATE()+10
AND AN.PERSONID IS NOT NULL
AND A.GRUPP IS NOT NULL
GROUP BY AN.PERSONID, A.GRUPP
Den tar dock väldigt väldigt lång tid att köra. Finns det något sätt jag kan snabba upp den på?
Execution plan ger följande resultat
Node Statistics
Estimates
Description
RowsReturned
1.5256
Number of rows returned
PercentTotalCost
99.985
Run time as a percent of total query time
RunTime
0.40253
Time to compute the results
CPUTime
0.16925
Time required by CPU
DiskReadTime
0.23328
Time to perform reads from disk
DiskWriteTime
0
Time to perform writes to disk
DiskRead
194.4
Disk reads
DiskWrite
0
Disk writes
Subtree Statistics
Estimates
Description
RowsReturned
1.5256
PercentTotalCost
100
RunTime
0.40259
CPUTime
0.16931
DiskReadTime
0.23328
DiskWriteTime
0
DiskRead
194.4
Disk reads
DiskWrite
0
Disk writes
Optimizer statistics
Value
Description
Costed subplans
14
Number of different enumeration strategies considered by the optimizer
Estimated cache pages
64009
Estimated cache pages available for this statement
CurrentCacheSize
523788
Current cache size in kilobytes
Isolation_level
0
Controls the locking isolation level
Optimization_goal
All-rows
Optimize queries for first row or all rows
Optimization_level
9
Reserved
Optimization_workload
Mixed
Controls whether optimizing for OLAP or mixed queries
ProductVersion
9.0.2.2451
Product version
User_estimates
Override-magic
Controls whether to respect user estimates
Select list
AN.PERSONID
char(11)
A.GRUPP
char(20)
Varför har du left join då du ändå ställer villkor på de högra tabellerna i din where-klausul?
Se till att de kolumner som finns i join-villkoren är indexerade. Förmodligen kan index på enhet också hjälpa.
Vad gör det för skillnad om jag byter från left join till outer join?
Jag ställer ju frågor på flera tabeller.
Tyvärr kan jag inte skapa index då jag bara har läsrättigheter på databasen tyvärr.
En left join är en (av tre varianter av) outer join. Jag menade att du skulle byta till inner join (och ta bort villkoren med is not null), eftersom det i alla fall blir samma resultat med dina nuvarande where-villkor.
Utan vettiga index kan du aldrig få någon bra prestanda om du inte har små datamängder.
Om vi nu får adminrättigheter och sätter några index så kan det inte göra att något i andra applikationer som använder databasen börjar fungera annorlunda?
Ja, insert/delete/update av indexerade fält är normalt långsammare än på oindexerade fält. Men att foreign keys inte är indexerade låter nästan som en bugg i mina öron. Tanken är ju att man ska joina på sådana fält, och om man inte har index när man gör joins blir det segt.
