Sitter och försöker förstå hur jag ska utnyttja stored procedures i MySql. Det går inget bra att konvertera! Vilka är de största skillnaderna? Jag försökte med MySql Migration Tool men det ville inte fungera så värst bra.
Till att börja med har jag den här frågan:
ALTER PROCEDURE dbo.spDefaultDisplayOrders
@CompanyID int
AS
SET NOCOUNT ON;
BEGIN
SELECT
tblInvoice.InvoiceID,
tblInvoice.InvoicePrefix + '' + convert(varchar, tblInvoice.InvoiceNumber) AS InvoiceNumber,
tblCustomers.Name as Customer,
tblInvoice.EndDate,
IsNull(tblInvoice.KmPrice * tblInvoice.Km, 0) * (1 + tblInvoice.GST) AS KmTotal,
IsNull(myHourTotal.HourTotal, 0) * (1 + tblInvoice.GST) AS HourTotal,
IsNull(myProductTotal.ProductTotal, 0) * (1 + tblInvoice.GST) AS ProductTotal,
(IsNull(tblInvoice.KmPrice * tblInvoice.Km, 0) + IsNull(myHourTotal.HourTotal, 0) + IsNull(myProductTotal.ProductTotal, 0)) * (1 +tblInvoice.GST) AS TOTAL
FROM
tblInvoice
LEFT OUTER JOIN
SELECT
SUM(dbo.LineTotal(tblInvoiceDetails.Quantity, tblInvoice.HourPrice, 0, tblInvoice.GST, 1)) AS HourTotal
FROM
tblInvoice
LEFT OUTER JOIN tblInvoiceDetails ON tblInvoice.InvoiceID = tblInvoiceDetails.InvoiceID
WHERE
(tblInvoiceDetails.InvoiceID = tblInvoice.InvoiceID)
GROUP BY
) AS myHourTotal
ON tblInvoice.InvoiceID = myHourTotal.InvoiceID
LEFT OUTER JOIN
SELECT
SUM(dbo.LineTotal(tblProducts.Quantity, tblProducts.UnitPrice, 0, tblInvoice.GST, 1)) AS ProductTotal
FROM
tblInvoice
LEFT OUTER JOIN tblProducts ON tblInvoice.InvoiceID = tblProducts.InvoiceID
WHERE
(tblProducts.InvoiceID = tblInvoice.InvoiceID)
GROUP BY
) AS myProductTotal
ON tblInvoice.InvoiceID = myProductTotal.InvoiceID
INNER JOIN tblCustomers ON tblInvoice.CustomerID = tblCustomers.CustomerID
GROUP BY
tblInvoice.InvoicePrefix + '' + convert(varchar, tblInvoice.InvoiceNumber),
tblCustomers.Name,
tblInvoice.EndDate,
IsNull(tblInvoice.KmPrice * tblInvoice.Km, 0) * (1 + tblInvoice.GST),
IsNull(myHourTotal.HourTotal, 0) * (1 + tblInvoice.GST),
IsNull(myProductTotal.ProductTotal, 0) * (1 + tblInvoice.GST),
ORDER BY
END
Först försökte jag kopiera in den i MySQL men det var rätt meningslöst då jag får fel på i princip varenda rad. Någon som kan peka på vad som måste rättas till? Det enklaste vore kanske att börja med en tom procedure?
