aspMedlem sedan aug. 2002733 inlägg Hoho...
För att räkna antalet vinster använder jag följande kod:
SQL = "SELECT Count(*) FROM Matcher WHERE " & _
"(homeID = " & ID & " AND homeGoals > awayGoals) OR " & _
"(awayID = " & ID & " AND homeGoals < awayGoals)"
Nu vill jag räkna ut flest matcher i rad utan förlust. Jag vet hur jag löser detta i ASP kod, men tänkte om det gick att ordna direkt i SQL satsen.
/ Marcus
Peter SMedlem sedan dec. 20025 483 inlägg Med referens till <http://www.sqlteam.com/item.asp?ItemID=12654> kan vi skriva
select case when
(homeid = <ID> and homegoals >= awaygoals)
or
(awayid = <ID> and awaygoals >= homegoals) then 1 else 0
end as point
, (select count(*)
from matcher
where <date column> < m.<date column>
and ((homeid = <ID> and homegoals < awaygoals)
or
(awayid = <ID> and awaygoals < homegoals))) as rg
, count(*) as streak
from matcher m
where (homeid = <ID> and homegoals >= awaygoals)
or (awayid = <ID> and awaygoals >= homegoals)
group
by point
, rg
order
by streak desc
limit 1
aspMedlem sedan aug. 2002733 inlägg Det var väl ganska väntat att jag skulle få ett felmeddelande...
SQL = "select case when " & _
"(homeid = " & ID & " and homegoals >= awaygoals) " & _
"or " & _
"(awayid = " & ID & " and awaygoals >= homegoals) then 1 else 0 " & _
"end as point " & _
", (select count(*) " & _
"from matcher " & _
"where matchdate < m.matchdate " & _
"and ((homeid = " & ID & " and homegoals < awaygoals) " & _
"or " & _
"(awayid = 1 and awaygoals < homegoals))) as rg " & _
", count(*) as streak " & _
"from matcher m " & _
"where (homeid = " & ID & " and homegoals >= awaygoals) " & _
"or (awayid = " & ID & " and awaygoals >= homegoals) " & _
"group " & _
"by point " & _
", rg " & _
"order " & _
"by streak desc " & _
"limit 1"
...ger...
Error Type:
(0x80004005)
Unspecified error
/stat/test.asp, line 38
Line 38 är koden då jag kör SQL-satsen. Den klagar alltså på SQL-satsen... ;-)
Peter SMedlem sedan dec. 20025 483 inlägg Vilket DBMS? Om SQL Server:
select top 1 case when
or
end as point
, (select count(*)
from matcher
or
from matcher m
group
by point
, rg
order
by streak desc
Läs gärna @nders guide till vad som bör inkluderas då frågor ställs.
aspMedlem sedan aug. 2002733 inlägg Access... sorry... glömmer alltid av sånt =)
Peter SMedlem sedan dec. 20025 483 inlägg Testa
select top 1
iif((homeid = <ID> and homegoals >= awaygoals)
or
(awayid = <ID> and awaygoals >= homegoals),1,0) as point
, (select count(*)
from matcher
or
from matcher m
group
by point
, rg
order
by streak desc
aspMedlem sedan aug. 2002733 inlägg <ID> Skall väl ersättas med " & ID & " ??
SQL = "select top 1 " & _
" iif((homeid = " & ID & " and homegoals >= awaygoals) " & _
" or " & _
" (awayid = " & ID & " and awaygoals >= homegoals),1,0) as point " & _
" , (select count(*) " & _
" from matcher " & _
" where matchdate < m.matchdate " & _
" and ((homeid = " & ID & " and homegoals < awaygoals) " & _
" or " & _
" (awayid = " & ID & " and awaygoals < homegoals))) as rg " & _
" , count(*) as streak " & _
" from matcher m " & _
" where (homeid = " & ID & " and homegoals >= awaygoals) " & _
" or (awayid = " & ID & " and awaygoals >= homegoals) " & _
"group " & _
" by point " & _
" , rg " & _
"order " & _
" by streak desc"
Gav...
Error Type:
Microsoft JET Database Engine (0x80040E21)
You tried to execute a query that does not include the specified expression 'IIf(homeid=334 And homegoals>=awaygoals Or awayid=334 And awaygoals>=homegoals,1,0)' as part of an aggregate function.
