Hej varför fungerar inte det här?
strSql=("Select * from tblMedlem Order By intLvl Desc Limit " & (intPage-1)*intPagesize & "," & intPageSize & " [b]Where intAntalInloggningar > 0[/b]")
Feltyp:
Microsoft OLE DB Provider for ODBC Drivers (0x80040E14)
You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 'Where intAntalInloggningar > 1' at line 1
Tack på förhand
