Problem vid import (#1064)
1 svar · 286 visningar · startad av SimOnline
SimOnlineMedlem sedan juli 20031 051 inlägg
Jag försöker importera från en .sql-fil till min MySQL-databas, men det vägrar fungera.
Så här ser .sql-filen ut:
# Table structure for table `scBookmarks`
CREATE TABLE `scBookmarks` (
  `bId` int(11) NOT NULL auto_increment,
  `uId` int(11) NOT NULL default '0',
  `bIp` varchar(40) default NULL,
  `bStatus` tinyint(1) NOT NULL default '0',
  `bDatetime` datetime NOT NULL default '0000-00-00 00:00:00',
  `bModified` datetime NOT NULL default '0000-00-00 00:00:00',
  `bTitle` varchar(255) NOT NULL default '',
  `bAddress` varchar(255) NOT NULL default '',
  `bDescription` varchar(255) default NULL,
  PRIMARY KEY  (`bId`),
  UNIQUE KEY `scBookmarks_bStatus_bId_bDatetime` (`bStatus`,`bId`,`bDatetime`),
  KEY `scBookmarks_uId_bAddress` (`uId`,`bAddress`)
# Table structure for table `scCategories`
CREATE TABLE `scCategories` (
  `id` int(11) NOT NULL auto_increment,
  `bId` int(11) NOT NULL default '0',
  `category` varchar(32) NOT NULL default '',
  PRIMARY KEY  (`id`),
  UNIQUE KEY `scCategories_category_bId` (`category`,`bId`),
  KEY `scCategories_bId` (`bId`)
# Table structure for table `scUsers`
CREATE TABLE `scUsers` (
  `uId` int(11) NOT NULL auto_increment,
  `username` varchar(25) NOT NULL default '',
  `password` varchar(75) NOT NULL default '',
  `uStatus` varchar(15) NOT NULL default 'active',
  `uDatetime` datetime NOT NULL default '0000-00-00 00:00:00',
  `uModified` datetime NOT NULL default '0000-00-00 00:00:00',
  `name` varchar(50) NOT NULL default '',
  `email` varchar(50) NOT NULL default '',
  `homepage` varchar(100) default NULL,
  `uContent` text,
  PRIMARY KEY  (`uId`)
# Table structure for table `scWatched`
CREATE TABLE `scWatched` (
  `wId` int(11) NOT NULL auto_increment,
  `watched` int(11) NOT NULL default '0',
  PRIMARY KEY  (`wId`),
  KEY `scWatched_uId` (`uId`)
Detta felmeddelande dyker upp:
 MySQL sa:
#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'CREATE  TABLE  `scCategories` (  `id` int( 11  )  NOT  NULL  AUTO_INCREMENT ,
 `' at line 12
Jag är väldigt dålig på SQL, så hjälp tas tacksamt emot.
TravoniMedlem sedan okt. 20041 538 inlägg
Ingen aning om varför, men jag fick det att funka om jag körde en tabell i taget.
Genererad på 376 ms · cache AV · v20260730165559-full.f96bc7eb
