Problem med hockeytabell
2 svar · 250 visningar · startad av andreas_lindh
andreas_lindhMedlem sedan jan. 20011 140 inlägg
Jag har den frågan som räknar ut en hockeytabell
ALTER PROCEDURE cup_getTabell
@groupID int
AS
	Select
		t.Namn,t.ID,
		sum(case when (t.ID = g.homeTeam and g.HomeScore > g.awayScore)
		or (t.id = g.awayTeam and g.homeScore < g.awayScore) and g.gameEnded = 1
		and c.playOff = 0 then 1 else 0 end) +
		sum(case when (t.ID = g.homeTeam and g.HomeScore < g.awayScore)
		or (t.id = g.awayTeam and g.homeScore > g.awayScore) and g.gameEnded = 1
		sum(case when ((t.ID = g.homeTeam and g.HomeScore = g.awayScore)
		and g.gameEnded = 1 and c.playOff = 0 or (t.id = g.awayTeam and g.homeScore = g.awayScore)
		and g.gameEnded = 1 and c.playOff = 0) then 1 else 0 end) as gamesPlayed,
		and c.playOff = 0 then 1 else 0 end) as wins,
		and c.playOff = 0 then 1 else 0 end) as losses,
		and g.gameEnded = 1 and c.playOff = 0) then 1 else 0 end) as ties,
		(sum(case when (t.ID = g.homeTeam and g.HomeScore > g.awayScore)
		and c.playOff = 0 then 1 else 0 end)*2) +
		sum(case when (t.ID = g.homeTeam and g.HomeScore = g.awayScore)
		and g.gameEnded = 1 and c.playOff = 0 then 1 else 0 end) as points,
		sum((case when t.ID = g.homeTeam and g.gameEnded = 1
		and c.playOff = 0 then 1 else 0 end)*homeScore +
		(case when t.ID = g.awayTeam and g.gameEnded = 1
		and c.playOff = 0 then 1 else 0 end) * awayScore) as GoalsForward,
		and c.playOff = 0 then 1 else 0 end)*awayScore +
		and c.playOff = 0 then 1 else 0 end) * homeScore) as GoalsAgainst,
		and c.playOff = 0 then 1 else 0 end) * awayScore) -
		and c.playOff = 0 then 1 else 0 end) * homeScore) as goalDifference
	from
	 cup_deltagande_lag as t
		left join cup_games as g
		on (t.ID = g.homeTeam or t.ID = g.awayTeam)
	left join cup_grupper as c
		on c.id = g.groupID
	where
		t.gruppID = @groupID and c.playoff = 0
	group by
		t.ID,t.Namn,c.playoff,t.gruppID
	order by
		points desc, goaldifference Desc, goalsforward desc, t.Namn Asc
Problemet är att den räknar med matcher som inte är slut g.gameended = 0.
lägger jag till where g.gameended = 1 så fungerar det men då visas inte lagen som inte spelat några matcher.
Finns det något sätt att lösa det här på eller måste jag ha med where g.gameended = 1?
Problemet är at tdu tar med c.playoff i where-satsen, vilket gör att LEFT-joinarna tvingas bli INNER-joinar. Använd gärna en derived table som bas, eftersom det blir enklare att få översikt
SELECT t.Namn,
    t.ID,
    t.gruppID,
    s.*
FROM cup_deltagande_lag AS t,
    (SELECT t.ID,
        COUNT(CASE WHEN g.gameEnded = 1 AND c.playOff = 0 THEN 1 ELSE 0 END)        AS gamesPlayed,
        SUM(CASE WHEN g.gameEnded   = 1 AND c.playOff = 0 AND t.ID = g.homeTeam AND g.HomeScore > g.awayScore THEN 1 ELSE 0 END)                      AS homeWins,
        SUM(CASE WHEN g.gameEnded   = 1 AND c.playOff = 0 AND t.ID = g.homeTeam AND g.HomeScore < g.awayScore THEN 1 ELSE 0 END)                      AS homeLosses,
        SUM(CASE WHEN g.gameEnded   = 1 AND c.playOff = 0 AND t.ID = g.awayTeam AND g.HomeScore < g.awayScore THEN 1 ELSE 0 END)                      AS awayWins,
        SUM(CASE WHEN g.gameEnded   = 1 AND c.playOff = 0 AND t.ID = g.awayTeam AND g.HomeScore > g.awayScore THEN 1 ELSE 0 END)                      AS awayLosses,
        SUM(CASE WHEN g.gameEnded   = 1 AND c.playOff = 0 AND (t.ID = g.awayTeam OR t.ID=g.homeTeam) AND g.HomeScore = g.awayScore THEN 1 ELSE 0 END) AS [ties],
        SUM(CASE WHEN g.gameEnded   = 1 AND c.playOff = 0 THEN CASE WHEN t.ID = g.homeTeam THEN g.HomeScore ELSE g.awayScore END ELSE 0 END)          AS goalsForward,
        SUM(CASE WHEN g.gameEnded   = 1 AND c.playOff = 0 THEN CASE WHEN t.ID = g.awayTeam THEN g.HomeScore ELSE g.awayScore END ELSE 0 END)          AS goalsAgainst
    FROM cup_deltagande_lag t
    LEFT JOIN cup_games AS g
        ON ( (t.ID = g.homeTeam OR t.ID = g.awayTeam) )
    LEFT JOIN cup_grupper AS c
        ON c.id = g.groupID
    GROUP BY t.ID
    ) AS s
WHERE t.gruppID = 1 AND t.ID=s.ID
Löste det. hade missat några parenteser
144 ms totalt · 3 externa anrop · v20260731065814-full.30151723
