Försöker tillåta null-värden i en access databas men får det inte att fungera.
Felmeddelande: Invalid SQL statement; expected 'DELETE', 'INSERT', 'PROCEDURE', 'SELECT', or 'UPDATE'.
SQL(6) = "SET NULL ON, CREATE TABLE [fk] ("
SQL(6) = SQL(6) & "[Id] counter ,"
SQL(6) = SQL(6) & "[kontakter] integer NOT NULL ,"
SQL(6) = SQL(6) & "[klar] integer DEFAULT 0 ,"
SQL(6) = SQL(6) & "[telefon] text(13) NOT NULL ,"
SQL(6) = SQL(6) & "[fnamn] text(255) NOT NULL ,"
SQL(6) = SQL(6) & "[enamn] text(255) NOT NULL ,"
SQL(6) = SQL(6) & "[pnr] text(10) NOT NULL ,"
SQL(6) = SQL(6) & "[a] text(8) ,"
SQL(6) = SQL(6) & "[b] text(8) ,"
SQL(6) = SQL(6) & "[c] text(10) ,"
SQL(6) = SQL(6) & "[d1] memo ,"
SQL(6) = SQL(6) & "[d2] integer DEFAULT 0,"
SQL(6) = SQL(6) & "[d3] memo ,"
SQL(6) = SQL(6) & "PRIMARY KEY ([Id]))"
