Och då kontrar jag med: :bire
In SQL Server version 6.5 and earlier, stored procedures were a way to partially precompile an execution plan. At the time the stored procedure was created, a partially compiled execution plan was stored in a system table. Executing a stored procedure was more efficient than executing an SQL statement because SQL Server did not have to compile an execution plan completely, it only had to finish optimizing the stored plan for the procedure. Also, the fully compiled execution plan for the stored procedure was retained in the SQL Server procedure cache, meaning that subsequent executions of the stored procedure could use the precompiled execution plan.
SQL Server 2000 and SQL Server version 7.0 incorporate a number of changes to statement processing that extend many of the performance benefits of stored procedures to all SQL statements. SQL Server 2000 and SQL Server 7.0 do not save a partially compiled plan for stored procedures when they are created. A stored procedure is compiled at execution time, like any other Transact-SQL statement. SQL Server 2000 and SQL Server 7.0 retain execution plans for all SQL statements in the procedure cache, not just stored procedure execution plans. The database engine uses an efficient algorithm for comparing new Transact-SQL statements with the Transact-SQL statements of existing execution plans. If the database engine determines that a new Transact-SQL statement matches the Transact-SQL statement of an existing execution plan, it reuses the plan. This reduces the relative performance benefit of precompiling stored procedures by extending execution plan reuse to all SQL statements.
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/architec/8_ar_da_0nxv.asp
Och här kan ni läsa lite om vilka algoritmer SQL servern använder för att hitta cachade execution plans för dynamiska sql frågor och om den inte hittar så compilerar den den och lägger in i cachen utifall någon kommer exekvera samma fråga igen.
When any SQL statement is executed in SQL Server 2000, the relational engine first looks through the procedure cache to verify that an existing execution plan for the same SQL statement exists. SQL Server 2000 reuses any existing plan it finds, saving the overhead of recompiling the SQL statement. If no existing execution plan exists, SQL Server 2000 generates a new execution plan for the query.
SQL Server 2000 has an efficient algorithm to find any existing execution plans for any given SQL statement. In most systems, the minimal resources used by this scan are less than the resources saved by being able to reuse existing plans instead of compiling every SQL statement.
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/architec/8_ar_sa_99wl.asp
Procedures har en färdigkompilerad execution plan.
Nä, nte i nyare versioner av SQL server, där kompileras den vid första körningen och sen cachas(kolla ovan), precis samma sak sker med dynamiska sql frågor, de kompileras vid första körningen och sen läggs i cachen. A stored procedure is compiled at execution time, like any other Transact-SQL statement
Det är ingen skillnad mellan SP och dynamiska sqlfrågor längre. Förutom det att när man ställer en dynamisk sql fråga så kommer SQL servern att leta igenom alla execution plans som finns i cachen och använda den som matchar, om den inte finns så kompileras den och läggs i cachen. Men denna "sökning" tar upp så minimala resurser att man inte behöver bry sig. In most systems, the minimal resources used by this scan are less than the resources saved by being able to reuse existing plans instead of compiling every SQL statement.
