Går detta att göra enklare och med mindre connections?
Databaser & SQL
0 svar · 199 visningar · startad av Addeladde
Medlem sedan jan. 20013 406 inlägg
Jag ska ta bort en katalog och alla underkataloger samt sidorna som ligger i katalogerna.
Så här ser min kod ut nu, går det att göra enklare?
If action = "DELETEFOLDER" and isNumeric(actionFolderID) Then
	Function getCatalogs(Byval actionOpenFolder, Byref strActionFolders)
	  Set checksystemFoldersRs = Con.Execute("Select folderID from folders where folderParent = "& actionOpenFolder)
	  While not checksystemFoldersRs.Eof
		strActionFolders = strActionFolders&checksystemFoldersRs("folderID")&","
		call getCatalogs(checksystemFoldersRs("folderID"), strActionFolders)
	    checksystemFoldersRs.MoveNext
	  Wend
	  checksystemFoldersRs.Close : Set checksystemFoldersRs = Nothing
	End Function
	call getCatalogs(actionFolderID, strActionFolders)
	sqlString = "Select sida_id from sidor Where (sida_typ = 1 or sida_typ= 2) And (sida_folderID = "& actionFolderID
	If strActionFolders <> "" Then
	  strActionFolders = left(strActionFolders, (len(strActionFolders)-1))
	  arrActionFolders = split(strActionFolders, ",")
	  For i=0 To ubound(arrActionFolders) step 1
		  sqlString = sqlString & " Or sida_folderID = "& arrActionFolders(i)
	  Next
	sqlString = sqlString&")"
	Set checksystemPagesRS = Con.Execute(sqlString)
    If not checksystemPagesRS.Eof Then
	  errorMessage = "Mappen innehåller en systemsida och kan ej tas bort!"
	checksystemPagesRS.close : set checksystemPagesRS = nothing
  If errorMessage = "" Then
	sqlString = "Delete from sidor Where sida_folderID = "& actionFolderID
	  Next
	sqlString = "Delete from folders Where folderID = "& actionFolderID
		  sqlString = sqlString & " Or folderID = "& arrActionFolders(i)
	  Next
  Else
256 ms totalt · 4 externa anrop · v20260731065814-full.6fe65c25
126 ms — deklarationer (db)
126 ms — ändringar (db)
