Jag skulle kunna vilja byta färg på både text och bakgrund genom att välja i en meny!
#include <windows.h>
#include <stdio.h>
#include <string.h>
#define IDM_MENU1 1
#define BGblack 202
#define BGwhite 201
#define TEXTblack 102
#define TEXTwhite 101
LRESULT CALLBACK MainWndProc(HWND hwnd,UINT uMsg,WPARAM wParam,LPARAM lParam);
HWND hwndMain;
HINSTANCE hInst;
char uttext [50];
char temp[10];
char str[45];
int xPos;
int yPos;
HDC hdc;
WNDCLASS wc;
WINAPI WinMain(HINSTANCE hInstance, HINSTANCE hPrevInstance, LPSTR lpszCmdLine, int nCmdShow)
MSG msg;
HMENU MinMeny;
// Register the Windows class
if (!hPrevInstance)
wc.style = 0;
wc.lpfnWndProc = (WNDPROC) MainWndProc;
wc.cbClsExtra = 0;
wc.cbWndExtra = 0;
wc.hInstance = hInstance;
wc.hIcon = LoadIcon(hInstance,
MAKEINTRESOURCE(1));
wc.hCursor = LoadCursor(hInstance,
wc.hbrBackground = (HBRUSH)GetStockObject(WHITE_BRUSH);
wc.lpszMenuName = "MainMenu";
wc.lpszClassName = "myMainWndClass";
if (!RegisterClass(&wc))
return FALSE;
hInst = hInstance; // save instance handle
MinMeny = LoadMenu(hInst, MAKEINTRESOURCE(IDM_MENU1)) ;
// Create the main window.
hwndMain = CreateWindow(
"myMainWndClass", // class name
"Christer Corneliusson", // window name
WS_OVERLAPPEDWINDOW | // overlapped window
WS_HSCROLL | // horizontal scroll bar
WS_VSCROLL, // vertical scroll bar
CW_USEDEFAULT, // default horizontal position
CW_USEDEFAULT, // default vertical position
CW_USEDEFAULT, // default width
CW_USEDEFAULT, // default height
(HWND) NULL, // no parent or owner window
MinMeny,//(HMENU) NULL, // class menu used
hInstance, // instance handle
NULL); // no window creation data
// If the main window cannot be created, terminate
// the application.
if (!hwndMain)
return FALSE;
// Show the window and paint its contents.
ShowWindow(hwndMain, nCmdShow);
UpdateWindow(hwndMain);
// Start the message loop.
while (GetMessage(&msg, (HWND) NULL, 0, 0))
TranslateMessage(&msg);
DispatchMessage(&msg);
// Return the exit code to Windows.
return msg.wParam;
HWND hwnd, // handle of window
UINT uMsg, // message identifier
WPARAM wParam, // first message parameter
LPARAM lParam) // second message parameter
switch (uMsg)
case WM_CREATE:
// Initialize the window.
break;
case WM_PAINT:
// Paint the window's client area.
break;
case WM_SIZE:
// Set the size and position of the window.
break;
case WM_COMMAND:
if (wParam == BGblack)
if (wParam == BGwhite)
if (wParam == TEXTblack)
if (wParam == TEXTwhite)
break;
case WM_RBUTTONUP:
break;
case WM_LBUTTONUP:
xPos = LOWORD(lParam); /* horizontal position of cursor */
yPos = HIWORD(lParam); /* vertical position of cursor */
strcpy(uttext, "Kordinaten du klickade på är: ");
itoa(xPos, temp, 10);
strcat(uttext, temp);
strcat(uttext, ",");
itoa(yPos, temp, 10);
MessageBox(0, uttext, /*szAppName*/"", MB_OK);
break;
case WM_CHAR:
if ((char)wParam =='q' ||(char)wParam =='Q' )
MessageBox(0, "HEJ DÅ!", /*szAppName*/"", MB_OK);
PostQuitMessage(0);
hdc = GetDC(hwnd);
sprintf(str, "du skrev: %c", (char) wParam );
TextOut(hdc, xPos, yPos, str, strlen(str));
ReleaseDC(hwnd, hdc);
break;
case WM_CLOSE:
// Create the message box. If the user clicks
// the Yes button, destroy the main window.
if (MessageBox(0, "Vill du verkligen avsluta ?", /*szAppName*/"",
MB_YESNO) == IDYES)
DestroyWindow(hwndMain);
break;
case WM_DESTROY:
// Quit when destroying the main window
PostQuitMessage(0);
break;
// Process other messages.
default:
return DefWindowProc(hwnd, uMsg, wParam, lParam);
return 0;
tack på förhand
