Byta färg i API
C/C++
2 svar · 203 visningar · startad av CoyPu
Medlem sedan apr. 200363 inlägg
Jag skulle kunna vilja byta färg på både text och bakgrund genom att välja i en meny!
#include <windows.h>
#include <stdio.h>
#include <string.h>
#define IDM_MENU1 1
#define BGblack   202
#define BGwhite   201
#define TEXTblack 102
#define TEXTwhite 101
LRESULT CALLBACK MainWndProc(HWND hwnd,UINT uMsg,WPARAM wParam,LPARAM lParam);
HWND hwndMain;
HINSTANCE hInst;
char uttext [50];
char temp[10];
char str[45];
int xPos;
int yPos;
HDC hdc;
WNDCLASS wc;
WINAPI WinMain(HINSTANCE hInstance, HINSTANCE hPrevInstance, LPSTR lpszCmdLine, int nCmdShow)
MSG msg;
HMENU MinMeny;
    // Register the Windows class
    if (!hPrevInstance)
        wc.style = 0;
        wc.lpfnWndProc = (WNDPROC) MainWndProc;
        wc.cbClsExtra = 0;
        wc.cbWndExtra = 0;
        wc.hInstance = hInstance;
        wc.hIcon = LoadIcon(hInstance,
            MAKEINTRESOURCE(1));
        wc.hCursor = LoadCursor(hInstance,
        wc.hbrBackground = (HBRUSH)GetStockObject(WHITE_BRUSH);
        wc.lpszMenuName =  "MainMenu";
        wc.lpszClassName = "myMainWndClass";
        if (!RegisterClass(&wc))
            return FALSE;
    hInst = hInstance;  // save instance handle
    MinMeny = LoadMenu(hInst, MAKEINTRESOURCE(IDM_MENU1)) ;
    // Create the main window.
    hwndMain = CreateWindow(
        "myMainWndClass",     // class name
        "Christer Corneliusson",           // window name
    WS_OVERLAPPEDWINDOW |   // overlapped window
        WS_HSCROLL |        // horizontal scroll bar
        WS_VSCROLL,         // vertical scroll bar
    CW_USEDEFAULT,          // default horizontal position
    CW_USEDEFAULT,          // default vertical position
    CW_USEDEFAULT,          // default width
    CW_USEDEFAULT,          // default height
    (HWND) NULL,            // no parent or owner window
    MinMeny,//(HMENU) NULL,           // class menu used
    hInstance,              // instance handle
    NULL);                  // no window creation data
    // If the main window cannot be created, terminate
    // the application.
    if (!hwndMain)
        return FALSE;
    // Show the window and paint its contents.
    ShowWindow(hwndMain, nCmdShow);
    UpdateWindow(hwndMain);
    // Start the message loop.
    while (GetMessage(&msg, (HWND) NULL, 0, 0))
        TranslateMessage(&msg);
        DispatchMessage(&msg);
    // Return the exit code to Windows.
    return msg.wParam;
    HWND hwnd,        // handle of window
    UINT uMsg,        // message identifier
    WPARAM wParam,    // first message parameter
    LPARAM lParam)    // second message parameter
    switch (uMsg)
        case WM_CREATE:
            // Initialize the window.
            break;
        case WM_PAINT:
            // Paint the window's client area.
            break;
        case WM_SIZE:
            // Set the size and position of the window.
            break;
        case WM_COMMAND:
            if (wParam == BGblack)
            if (wParam == BGwhite)
            if (wParam == TEXTblack)
            if (wParam == TEXTwhite)
        		break;
        case WM_RBUTTONUP:
        		break;
        case WM_LBUTTONUP:
            xPos = LOWORD(lParam);    /* horizontal position of cursor */
				yPos = HIWORD(lParam);    /* vertical position of cursor   */
            strcpy(uttext, "Kordinaten du klickade på är: ");
            itoa(xPos, temp, 10);
            strcat(uttext, temp);
            strcat(uttext, ",");
            itoa(yPos, temp, 10);
            MessageBox(0, uttext, /*szAppName*/"", MB_OK);
            break;
        case WM_CHAR:
        		if ((char)wParam =='q' ||(char)wParam =='Q' )
            	MessageBox(0, "HEJ DÅ!", /*szAppName*/"", MB_OK);
               PostQuitMessage(0);
           	hdc = GetDC(hwnd);
            sprintf(str, "du skrev: %c", (char) wParam );
            TextOut(hdc, xPos, yPos, str, strlen(str));
            ReleaseDC(hwnd, hdc);
            break;
        case WM_CLOSE:
        // Create the message box. If the user clicks
        // the Yes button, destroy the main window.
            if (MessageBox(0, "Vill du verkligen avsluta ?", /*szAppName*/"",
                MB_YESNO) == IDYES)
                DestroyWindow(hwndMain);
            break;
        case WM_DESTROY:
            // Quit when destroying the main window
            PostQuitMessage(0);
            break;
        // Process other messages.
        default:
            return DefWindowProc(hwnd, uMsg, wParam, lParam);
    return 0;
tack på förhand
Är osäker på om du med "bakgrund" menar hela bakgrunden eller bara själva textbakgrunden. Om du menar det första så är nog SetBkColor och SetTextColor två bra funktioner.
/red: Snurrade nog till det lite angående bakgrundsfärgen. Vill du sätta bakgrunden till svart kan du tex göra så här:
RECT r;
hdc = GetDC(hwnd);
GetClientRect(hwnd, &r);
FillRect(hdc, &r, (HBRUSH)GetStockObject(BLACK_BRUSH));
.. Och WHITE_BRUSH för vit.
tnx alot! det funka!
264 ms totalt · 4 externa anrop · v20260731065814-full.2f471f9e
126 ms — deklarationer (db)
130 ms — ändringar (db)
