Få felet:
Error: Unresolved external '_main' referenced from C:\PROGRAM\BORLAND\BCC55\LIB\COX32.obj
Vad beror det på?
#define WIN32_LEAN_AND_MEAN
#include <windows.h>
LRESULT CALLBACK WindowProc(HWND hwnd, UINT msg, WPARAM wparam, LPARAM lparam)
HDC hdc;
PAINTSTRUCT ps;
switch(msg)
case WM_CREATE:
return(0);
} break;
case WM_PAINT:
hdc = BeginPaint(hwnd, &ps);
EndPaint(hwnd,&ps);
return(0);
} break;
case WM_DESTROY:
PostQuitMessage(0);
return(0);
} break;
default: break;
return(DefWindowProc(hwnd, msg, wparam, lparam));
int WINAPI WinMain(HINSTANCE hInstance, HINSTANCE hPrevInstance, LPSTR lpCmdLine, int nCmdShow)
WNDCLASS winclass;
HWND hwnd;
MSG msg;
winclass.style = CS_DBLCLKS | CS_OWNDC |
CS_HREDRAW | CS_VREDRAW;
winclass.lpfnWndProc = WindowProc;
winclass.cbClsExtra = 0;
winclass.cbWndExtra = 0;
winclass.hInstance = hInstance;
winclass.hIcon = LoadIcon(NULL, IDI_APPLICATION);
winclass.hCursor = LoadCursor(NULL, IDC_ARROW);
winclass.hbrBackground = (HBRUSH)GetStockObject(BLACK_BRUSH);
winclass.lpszMenuName = NULL;
winclass.lpszClassName = "DirectXWindowClass";
if (!RegisterClass(&winclass))
return(0);
if (!(hwnd = CreateWindow("DirectXWindowClass",
"DirectX fönster",
WS_POPUP | WS_VISIBLE,
0,0,
640,
480,
NULL,
NULL,
hInstance,
NULL)))
while(1)
if(PeekMessage(&msg,NULL,0,0,PM_REMOVE))
if(msg.message == WM_QUIT)
break;
TranslateMessage(&msg);
DispatchMessage(&msg);
return(msg.wParam);
