Har nu kodat lite på blåtand och tänkte dela med mig.
rfcomm server
#include <stdio.h>
#include <unistd.h>
#include <sys/socket.h>
#include <bluetooth/bluetooth.h>
#include <bluetooth/rfcomm.h>
int main(int argc, char **argv)
struct sockaddr_rc loc_addr = { 0 }, rem_addr = { 0 };
char buf[1024] = { 0 };
int s, client, bytes_read;
socklen_t opt = sizeof(rem_addr);
// allocate socket
if((s = socket(AF_BLUETOOTH, SOCK_STREAM, BTPROTO_RFCOMM))==-1)
perror("socket");
// bind socket to port 21 of the first available
// local bluetooth adapter
loc_addr.rc_family = AF_BLUETOOTH;
loc_addr.rc_bdaddr = *BDADDR_ANY;
loc_addr.rc_channel = (uint8_t) 21;
if(bind(s, (struct sockaddr *)&loc_addr, sizeof(loc_addr))==-1)
perror("bind");
// put socket into listening mode
if(listen(s, 1)==-1)
perror("listen");
while(1)
// accept one connection
if((client = accept(s, (struct sockaddr *)&rem_addr, &opt)) == -1)
perror("accept");
ba2str( &rem_addr.rc_bdaddr, buf );
fprintf(stderr, "accepted connection from %s\n", buf);
memset(buf, 0, sizeof(buf));
// read data from the client
bytes_read = read(client, buf, sizeof(buf));
if( bytes_read > 0 ) {
printf("received [%s]\n", buf);
close(client);
// close connection
close(s);
return 0;
rfcoom client
#include <iostream>
#include <string>
using namespace std;
struct sockaddr_rc addr = { 0 };
int s, status;
char dest[18] = "00:80:37:27:1D:02";
// allocate a socket
s = socket(AF_BLUETOOTH, SOCK_STREAM, BTPROTO_RFCOMM);
// set the connection parameters (who to connect to)
str2ba( dest, &addr.rc_bdaddr );
// connect to server
status = connect(s, (struct sockaddr *)&addr, sizeof(addr));
string str;
if(argc >0)
str = argv[1];
cout<<str<<endl;
// send a message
if( status == 0 ) {
status = write(s, str.c_str(), str.size());
if( status < 0 ) perror("uh oh");
close(s);
return 0;
scanner
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <bluetooth/hci.h>
#include <bluetooth/hci_lib.h>
inquiry_info *ii = NULL;
int max_rsp, num_rsp;
int dev_id, sock, len, flags;
int i;
char addr[19] = { 0 };
char name[248] = { 0 };
dev_id = hci_get_route(NULL);
sock = hci_open_dev( dev_id );
if (dev_id < 0 || sock < 0) {
perror("opening socket");
exit(1);
len = 8;
max_rsp = 255;
flags = IREQ_CACHE_FLUSH;
ii = (inquiry_info*)malloc(max_rsp * sizeof(inquiry_info));
num_rsp = hci_inquiry(dev_id, len, max_rsp, NULL, &ii, flags);
if( num_rsp < 0 ) perror("hci_inquiry");
for (i = 0; i < num_rsp; i++) {
ba2str(&(ii+i)->bdaddr, addr);
memset(name, 0, sizeof(name));
if (hci_read_remote_name(sock, &(ii+i)->bdaddr, sizeof(name),
name, 0) < 0)
strcpy(name, "[unknown]");
printf("%s %s\n", addr, name);
free( ii );
close( sock );
return 0;
l2cap server
#include <stdio.h>
#include <string.h>
#include <bluetooth/l2cap.h>
struct sockaddr_l2 loc_addr = { 0 }, rem_addr = { 0 };
int opt = sizeof(rem_addr);
// allocate socket
s = socket(AF_BLUETOOTH, SOCK_SEQPACKET, BTPROTO_L2CAP);
// bind socket to port 0x1001 of the first available
// bluetooth adapter
loc_addr.l2_family = AF_BLUETOOTH;
loc_addr.l2_bdaddr = *BDADDR_ANY;
loc_addr.l2_psm = htobs(0x1001);
bind(s, (struct sockaddr *)&loc_addr, sizeof(loc_addr));
listen(s, 1);
client = accept(s, (struct sockaddr *)&rem_addr, &opt);
ba2str( &rem_addr.l2_bdaddr, buf );
// close connection
close(client);
close(s);
l2cap client
#include <stdio.h>
#include <string.h>
struct sockaddr_l2 addr = { 0 };
int s, status;
char *message = "hello!";
char dest[18] = "01:23:45:67:89:AB";
if(argc < 2)
fprintf(stderr, "usage: %s <bt_addr>\n", argv[0]);
exit(2);
strncpy(dest, argv[1], 18);
str2ba( dest, &addr.l2_bdaddr );
// send a message
if( status == 0 ) {
status = write(s, "hello!", 6);
close(s);
