För er som tycker att det är svårt att höra. :)
02:55 Toronto Arrival
Air Canada 621, are you still there?
02:59 Toronto Arrival
Air Canda 621, xxxx?
03:03 Toronto Arrival
Air Canada 1105, they tell me we have got an aircraft slided off the end
of the runway. You will not be landing at runway 24L (left). Your
approach clearance is canceled. You're clear to maintain 4000
feet.
03:13 Air Canada 1105
Clear to 4000, Air Canada 1105, Requesting vectors direct London.
03:17 Toronto Arrival
Air Canada 1105, roger. Stear heading 220 degrees now, contiune climb 6000.
03:22 Air Canada 1105
Set 220 climb and continue 6000, Air Canada 1105
03:25 Toronto Arrival
Air Canada 1105, we want an expedious climb to 5000
03:29 Air Canada 1105
We expedite to 5, Air Canada 1105
03:31 Toronto Arrival
Air Canada 1156, turn to the left heading 200 degrees.
03:34 Air Canada 1156
Turn left heading 200, Air Canda 1156
03:37 Toronto Arrival
Air Canada 1156, I suggest you go for your alternative now. I
think the airport is going to be closed for quite a while.
03:42 Air Canada 1156
Ok, is anybody going to Trenton.
03:44 Toronto Arrival
Ah, not that I'm aware of. What is your alternative now?
03:48 Air Canada 1156
London Ontario
03:49 Toronto Arrival
London is available if you got to do it
03:52 Air Canada 1156
Okay we take London
03:53 Toronto Arrival
Air Canada 1156, clear to London. By radar vectors, maintain 6000.
03:57 Air Canada 1156
Clear to 6000, go direct to London, Air Canada 1156.
04:02 Toronto Arrival
Air Canada 1105, your report level is 6000 feet
04:06 Air Canada 1105
Report at level 6000, Air Canada 1105
04:10 Toronto Arrival
Vectoring direct Syracuse and climb shortly.
04:13 Toronto Arrival
KLM 691
04:15 KLM 691
XXXX the airport closed now, KLM 691?
04:17 Toronto Arrival
I believe an aircraft went off the run at the end of the runway
and crashed. So right now just maintain 180 heading and 4000.
04:25 KLM 691
KLM 691, copy.
04:53 Air Canada 1105
Air Canada 1105 level at 6000.
04:56 Toronto Arrival
Air Canda 1105, thank you.
04:59 KLM 691
PAN PAN PAN, KLM 691, We have a low fuel emergency for our
diversion to Syracuse. Declaring a low fuel emergency. KLM 691
05:09 Toronto Arrival
KLM 691, Roger. Check your XXXX declaring fuel emergency, Are
you able to go to Hamilton Airport. What's the minimum length of
runway I can have. Maybe XXXX a closer one.
05:21 KLM 691
We need a less XXXX Syracuse. We have got just about fuel to get to
Syracuse and land there with 30 minutes, KLM 691.
05:31 Toronto Arrival
KLM 691, Roger. Direct to Syracuse maintain 5000.
05:35 KLM 691
Direct to Syracuse maintain 5000, KLM 691
