Är du immun mot HIV? Det finns en möjlighet du kan va
Datasäkerhet
9 svar · 596 visningar · startad av His Divine Shadow
Medlem sedan sep. 20004 079 inlägg
Låter intressant, ett plus för genterapi, kanske det blir möjligt att ge vanliga människor denna gen.
http://www.pbs.org/wnet/secrets/case_plague/interview.html
This may not sound exciting, but delta 32 is a powerful mistake. HIV, the virus that causes AIDS, attacks the human immune system, infecting the white blood cells sent to destroy it. The delta 32 mutation, however, effectively blocks the crucial gateway into human cells the virus needs. In the case of Steve Crohn, whose partner was the fifth person to die from AIDS, possessing the CCR5 mutation has prevented him from contracting the virus.
O'Brien explains further, "In order to have total resistance to HIV, you have to carry two doses of the mutated gene -- one from each parent. If you get only one dose, you will not be resistant to infection. However, you may be able to delay the onset of HIV once you become infected. That's because, in patients with one copy of the mutation, the amount of 'portals' or 'doorways' that HIV can use is reduced by about 50 percent. That slows down virus replication, which is the most important factor in AIDS progression."
O'Brien's work on AIDS led him to another disease that delta 32 could prevent, the plague. "They both, upon entering the body, infect the microphages, which are the first line of defense against bacterial infections," he says. "Over the course of evolution, many bugs and pathogens have become extinct because the body learned how to defend itself against them. So the ones that are around today, like HIV and the plague, are pretty savvy -- HIV, for example, specifically attacks and kills the very cells that are designed to kill it. Both these pathogens have developed very clever ways around our immunological defenses."
Secrets of the Dead is a production of Thirteen/WNET New York. © 2002 Educational Broadcasting Corporation. All rights reserved
Medlem sedan mars 20021 889 inlägg
Upggifterna vekar ju komma från en säker källa också. ;)
Sarkasm? Tror du det inte är sant?
Hoppas det är sant iaf :)
Det finns andra källor som talar om det iaf.
http://www.hivandhepatitis.com/recent/prevention/092101c.html
Medlem sedan sep. 20021 655 inlägg
Om jag kan min biologi rätt är det s.k. makrofager som det talas om i texten ovan. Lustigt att de kallas för mikrofager på engelska.
Det finns folk i Usa som har blivit "våldtagna" av läkarbolag, dom har tagit patent på deras blod så att ingen annan ska kunna tjäna på deras blod...
Dom har "antikroppar" som gör att dom inte får hiv.
Har även läst att vi nordbor lär vara rätt "överrepresenterade" när det gäller sånt, det har att göra med någon av alla dessa sjukdomar som härjade på den mörka tidsåldern...
Nä, du hadde fel, jag också, verkar som Mikrofager är skillda från Makrofager, måste kolla lite info nu först.
I min "Medicinisk miniordbok" finns inte mikrofag med och en sökning efter "mikrofag" på Google gav bara en träff:
http://hem.passagen.se/pluver/m.html
Mikrofag - Cellätande mikroorganism i blodet
microphage ger också avsevärt färre träffar än macrophage, vilket får mig att undra om det inte handlar om en felskrivning.
Fast... här hittade jag en träff:
http://cancerweb.ncl.ac.uk/cgi-bin/omd?microphage
Jo, de är en sorts fagocyter.
Men Makro och Mikrocyter verkar höra till olika grupper, har också sett att mikrocyter utvecklas från nån slags stamcell till antingen Mikrocyter eller T-celler.
254 ms totalt · 4 externa anrop · v20260731065814-full.1dc6f849
124 ms — deklarationer (db)
123 ms — ändringar (db)
