Personlighetstest..
9 svar · 416 visningar · startad av bymarie
Medlem sedan aug. 20022 436 inlägg
Medlem sedan apr. 20013 480 inlägg
Your Mood: At the moment you want to reach out and make contacts with others. You are feeling friendly inside and others around you will unconsciously pick up on this. You want to connect with people and be sociable.You feel more determined than usual and are not prepared to put up with unnecessary delay or restriction. Not in the mood to be told what to do you resent anyone trying to control your behavior. You do not want to be held back at this time. . . .
Your Present Situation: You really need to take time out at the moment, your life is proving tiring and you seem to need to be on the lookout at all times. There is a real danger of wasting your energy, seek out someone who can help you to calm down and relax. You could do worse than take a romantic weekend break to help you revitalize yourself.Your present situation is causing you to feel overwhelmed and exhausted. The mental stress and physical exhaustion is just leading to other negative effects and is turning into a vicious cycle. You are at a loss on how to resolve your problems and are too tired to deal with most of them at the present time. . . .
Your Conflicts: You have no conflicts at the present time . . .
Medlem sedan maj 20021 141 inlägg
Skrämmande ju!
Allt som stog om mig stämde.
Jag har inte en aning om mitt stämmer...
Your Mood: You are probably feeling overwhelmed at the moment. It is as if you have too much on your plate and need time out. Perhaps you need a rest so that you can recharge your batteries; at the moment do not feel ready to take on more challenges. You feel more determined than usual and are not prepared to put up with unnecessary delay or restriction. Not in the mood to be told what to do you resent anyone trying to control your behavior. You do not want to be held back at this time. . . .
Your Present Situation: You really need to take time out at the moment, your life is proving tiring and you seem to need to be on the lookout at all times. There is a real danger of wasting your energy, seek out someone who can help you to calm down and relax. You could do worse than take a romantic weekend break to help you revitalize yourself.Your current situation is causing you a great deal of angst. Somehow you have become over-involved in something that is leading to feelings of stress and doubt. You are at risk of feeling overwhelmed and exhausted. . . .
Jag vet tydligen vad jag behöver ;)
Stämmde riktigt bra för mig :o
Medlem sedan maj 2001406 inlägg
Your Mood: At the moment your sensual and emotional needs are not being met. Perhaps you are finding life more than a little harsh at present. Being unable to relax is making you tired and taking the edge off your enthusiasm. You feel more determined than usual and are not prepared to put up with unnecessary delay or restriction. Not in the mood to be told what to do you resent anyone trying to control your behavior. You do not want to be held back at this time. . . .
Your Present Situation: Your current situation is causing you to feel detached and uninvolved. You feel little empathy for those around you, and this is leading you to be withdrawn from others. This is causing the vicious cycle of others withdrawing from you because they sense your lack of interest, then you taking that as a sign that no one is interested in your life, your needs.Your present situation is draining your energy levels and can be very frustrating. Whatever efforts you make things do not appear to be getting any better. You need to be very careful as your vitality at the moment is low and you may feel that you cannot meet the challenges of your present circumstances. It is important to realize that this phase is temporary, and if you are careful not to let despondency take over, you will triumph in the end. You can make the necessary changes in your life, but it may take some time. . . .
skrämmande sant för att säga det minsta ...
Your Mood: You feel quite determined at the moment or as others might say stubborn! You feel resolute and want things done your way. You want to exert your will and are prepared to put in the necessary energy.Focus and determined describes your present mood. You are out to achieve your goal and you concentrate on that. Unwavering you want to stick to the target of your ambitions, not completely to the exclusion of everything else, but almost! . . .
Your Present Situation: Your current situation is causing you to feel detached and uninvolved. You feel little empathy for those around you, and this is leading you to be withdrawn from others. This is causing the vicious cycle of others withdrawing from you because they sense your lack of interest, then you taking that as a sign that no one is interested in your life, your needs.You want to escape a stressful situation in your life but are afraid of the consequences. You worry that if you make changes you will be worse off. In a sense you are torn between your need to break out and the risks to your security that any changes might bring. . . .
Får alla samma?
Medlem sedan sep. 2000232 inlägg
Nä det verkar finnas ett antal meningar som slumpas runt.
263 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
123 ms — deklarationer (db)
128 ms — ändringar (db)
