Satan i gatan allså
17 svar · 161 visningar · startad av goldy
Medlem sedan apr. 20013 689 inlägg
§e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e §e
TOPPADE?
Ursäkta bara så satans utråkad!!
======goldy=======
<A HREF="http://www.go.to/theshakedowns" TARGET=_blank>db<---BURNER--->db</A>
Många vidriga luvor det blev där....
Mjölk löser inga problem, jag håller på och testar om sprit gör det nu.....
Medlem sedan okt. 2001509 inlägg
Man blir helt borta om man stirrar i några minuter..
Jag äger Konsum.
Medlem sedan apr. 20003 424 inlägg
:e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e :e
var bara tvungen att ta de som goldy missade :e
Tomtar rockar
eftersom att minsann är tjingad så måste jag vara gängad eller nått ;) :e :e
Holgerson, det gör man inte. :e
Medlem sedan mars 20012 635 inlägg
stirrar man förlänge så ser man ett mönster.
jag ser massa kryss
På julnatten kommer jag att lägga mej på taket och skjuta renar Men jag missade alla och fick äta anka.
Signatur redigerad av WooSteR 20011225
Rikard:
Joho.. :e
Jag äger Konsum.
Näpp! :e
Joho.. :e
Jag äger Konsum.
Holgersson>> Hur blir du om du stirrar i en timma då? :birp
Det vill jag inte veta.. :e
Jag äger Konsum.
Du är väl inte rädd? :stefan
Tänk om jag får några hjärnskador?
Ersätter du mig med en viss summa pengar då?
Jag äger Konsum.
Var i ligger skillnaden? §e
[Redigerat av Rikard den 26 dec 2001]
Men då kan du ju påstå att det blev som du är utan att stirra i en timma juh. Den lätte går jag inte på. :stefan
Nä, jag tror nog att jag skippar den här. Det räcker med några minuters stirrande för min del. Kanske att jag kollar lite i morrn eller så. Vi får se..
Jag äger Konsum.
Skriv ut den så kan du titta lite då och då oavsett vart du är. :birp
Det låter som en bra idé! Sen kan jag gå runt på stan och visa folk papperet och se vad de säger!
Jag äger Konsum.
122 ms — deklarationer (db)
130 ms — ändringar (db)
